Arch Linux on RockPro64
Quote:ah-, could you share where you got 4.18.0-rc8 from? I can't seem to find it neither in ayufan's linux-kernel repo, nor in his linux-mainline-kernel repo. Also, could you briefly describe how I would go about building it into a usable/install-able kernel if it's not too much to ask?
When you look into his PKGBUILD in his sources, you can find the link to the linux kernel resources he used to get the kernel sources from. Otherwise, you can also look into the linux-mainline-kernel repo of ayufan, under the tab 'Releases' you can also find his releases. ah- as well as myself use these resources to compile our kernels (even though I already upgraded to the 4.19 release).
You can look into the PKGBUILD file ah- created, you can also look into my repo (you'll find the link in the post above yours). Basically, you need to check out the git repository, install the base-devel package on your rockpro and then type 'makepkg' in the root of the downloaded sources. This will create a linux-aarch64.....tar.xz package that you can then install with 'pacman -U linux-aarch64.....tar.xz'
Alternatively, you can read the PKGBUILD file to see what is being done to compile the kernel (mine and ah- are identical in that aspect as we both used the same resources to create our packages). I also recommend you to read the article about creating packages in the arch wiki to better understand what is being done.
Hope that helps,
Matyas
PS: before you compile the kernel, make sure you edit the file /etc/makepkg.conf and uncomment the line
#MAKEFLAGS="-j5"
. You should also change the flag -j5 to -j7. This will tell your compiler to use all cores on your rockpro instead of just one, which will reduce the kernel compiling time from about 6 hours to about 1.
PPS: If I can give you a tip, do not compile a kernel on your SD card, use an external HDD or SSD instead. Most SD cards are not made to endure the write load that linux generates while compiling a kernel or using swap and will kill the card after a couple of weeks of heavy use.
Arch Linux on RockPro64 - by mmatyas - 07-29-2018, 03:31 PM
RE: Arch Linux on RockPro64 - by Tigger - 08-06-2018, 01:29 PM
RE: Arch Linux on RockPro64 - by hiccupstix - 08-06-2018, 03:40 PM
RE: Arch Linux on RockPro64 - by Tigger - 08-07-2018, 03:02 AM
RE: Arch Linux on RockPro64 - by mmatyas - 08-08-2018, 01:49 AM
Arch Linux on RockPro64 - by hiccupstix - 08-07-2018, 03:17 AM
RE: Arch Linux on RockPro64 - by Tigger - 08-08-2018, 04:48 AM
RE: Arch Linux on RockPro64 - by ah- - 08-28-2018, 03:14 PM
RE: Arch Linux on RockPro64 - by dukla2000 - 08-29-2018, 03:37 AM
RE: Arch Linux on RockPro64 - by ah- - 08-29-2018, 11:25 AM
RE: Arch Linux on RockPro64 - by ali - 11-09-2018, 08:54 AM
RE: Arch Linux on RockPro64 - by mmatyas - 11-06-2018, 03:47 PM
RE: Arch Linux on RockPro64 - by mmatyas - 11-20-2018, 06:29 PM
RE: Arch Linux on RockPro64 - by ali - 11-27-2018, 12:28 AM
RE: Arch Linux on RockPro64 - by p1x3l3d - 11-22-2018, 05:28 PM
RE: Arch Linux on RockPro64 - by mmatyas - 11-24-2018, 04:09 AM
RE: Arch Linux on RockPro64 - by p1x3l3d - 11-26-2018, 02:11 PM
RE: Arch Linux on RockPro64 - by p1x3l3d - 01-13-2019, 12:41 PM
RE: Arch Linux on RockPro64 - by mmatyas - 01-19-2019, 11:30 AM
RE: Arch Linux on RockPro64 - by mmatyas - 11-27-2018, 01:21 AM
RE: Arch Linux on RockPro64 - by ali - 12-01-2018, 07:16 AM
RE: Arch Linux on RockPro64 - by fosf0r - 12-03-2018, 09:59 AM
RE: Arch Linux on RockPro64 - by ali - 01-11-2019, 02:21 AM
RE: Arch Linux on RockPro64 - by mmatyas - 02-26-2019, 11:31 AM
RE: Arch Linux on RockPro64 - by mmatyas - 02-27-2019, 06:07 PM
RE: Arch Linux on RockPro64 - by mmatyas - 09-10-2019, 01:58 PM
RE: Arch Linux on RockPro64 - by oreggin - 09-26-2019, 03:09 PM
RE: Arch Linux on RockPro64 - by TaborFife - 09-28-2019, 04:30 AM
RE: Arch Linux on RockPro64 - by hev - 03-20-2020, 12:27 AM
RE: Arch Linux on RockPro64 - by rhysperry111 - 05-23-2020, 02:29 PM
RE: Arch Linux on RockPro64 - by mmatyas - 05-30-2020, 12:08 PM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 660 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 780 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,738 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 921 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,943 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 84,489 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,440 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 630 05-21-2023, 11:34 PM
Last Post: shpark
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,088 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Rockpro64 Dead on arrival? quixoticgeek 1 1,019 03-12-2023, 06:55 PM
Last Post: quixoticgeek
