Assembly Programming in Pine64
(04-13-2016, 05:29 AM)mustaphos Wrote: Is it possible to program the pine64 in pure assembly?
If it is possible in which compiler can i program it and how can i upload my code to the board?
For example: Get 2 64 bit numbers from memory, add them in registers and store them in the memory?
The pine uses an A64 SOC which incorporates a quad core A53 CPU. The A53 implements the Armv8-A architecture. (so much digging to get to the meat)
http://infocenter.arm.com/help/topic/com...p2_trm.pdf
https://static.docs.arm.com/den0024/a/DEN0024.pdf
Is it possible, I would imagine it is. However you are entering into a land with very few players, I'd be surprised to find more than 5 that bought a pine that have ever coded anything in assembler.  To further complicate matters you are going to have issues with other things connected to the CPU that use binary blobs instead of open source. Getting assembly level programming info for something closed source like the Mali 400, you can probably forget that. Not trying to sound discouraging just dont want you to get surprised.
http://infocenter.arm.com/help/index.jsp has lots of relvant info, including compilers. Gno binutils should also possibly work.
As for uploading code on the board, if you are planning on running just your assembled code you are going to need info on the boot system etc and other parts that I dont know if you will get a lot of success with. Good luck!
Assembly Programming in Pine64 - by mustaphos - 04-13-2016, 05:29 AM
RE: Assembly Programming in Pine64 - by rahlquist - 04-13-2016, 06:14 AM
RE: Assembly Programming in Pine64 - by frewind - 04-13-2016, 12:00 PM
RE: Assembly Programming in Pine64 - by dmartin - 05-13-2016, 12:08 PM
RE: Assembly Programming in Pine64 - by tllim - 05-13-2016, 04:40 PM
RE: Assembly Programming in Pine64 - by johnsl - 12-06-2016, 07:11 PM
  Programming languages support under PINE64 baryluk 6 12,444 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 5,961 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 24,648 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,076 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 6,048 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 35,619 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,131 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,718 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,657 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 37,598 10-26-2017, 05:51 PM
Last Post: gregjo
