Display limited to 800x600 [SOLVED]
(07-28-2018, 05:45 AM)ab1jx Wrote:
(07-28-2018, 04:53 AM)Averell Wrote: sledgehammerish, OK, but it worked. Replacing only the extlinux.conf file did not work. Replacing the dtb file did not work. replacing initrd.img file alone breaks the system. The problem was in the 0.5 kernel, and the question was if was possible to replace by the 0.6 kernel without breaking everything. I expected it would, but this didn't and the system is still running well.
When you replace the kernel (or initrd.img) you might have to do "update-initramfs -u", I'm not sure how that works.  I didn't backtrack on anything, just picked a mode with drm_kms_helper.  Did it before I found the PDF on how to do it, I think I got it from somebody on IRC.
I just did it again a year or so later.  I grabbed an EDID file using tvservice on a Raspberry Pi and put it in /lib/firmware/edid.  I didn't do the update-initramfs.  This time I wanted to get 1920x1080 which the Pi defaulted to anyway.  I'm not sure if it matters but I did this using the monitor I wanted to use, which worked on the Pi but not the Rock64 (until I made the EDID file).  I did have to power it off and back on, not just type reboot, before it worked.
So I have /lib/firmware/edid/piedid2.bin and in /boot/extlinux/extlnux.conf I have  drm_kms_helper.edid_firmware=edid/piedid2.bin  I did have to make the edid directory in /lib/firmware.
Display limited to 800x600 [SOLVED] - by Averell - 07-06-2018, 08:04 AM
RE: Display limited to 800x600 - by ab1jx - 07-07-2018, 05:16 PM
RE: Display limited to 800x600 - by Averell - 07-09-2018, 10:51 AM
RE: Display limited to 800x600 [SOLVED] - by ab1jx - 06-05-2020, 11:07 PM
Question [SOLVED] Alpine Linux won't boot rock7 1 5,816 10-22-2019, 04:30 PM
Last Post: rock7
  [solved] Unable to start X Osiander 8 11,524 10-03-2018, 03:54 AM
Last Post: jovval
  If you've messed up your eMMC Card - Solved gregb49 11 16,560 07-11-2018, 02:08 PM
Last Post: gregb49
  Any reason why ntp time is 6 minutes slow (Solved) Rocklobster 1 2,563 05-29-2018, 05:27 AM
Last Post: Rocklobster
  [Solved] Open VPN +Wi-Fi hotspot - Debian S3phi40T 1 2,935 05-01-2018, 05:51 AM
Last Post: S3phi40T
  [PROBLEM SOLVED] Distcc Help cooker 2 4,034 05-01-2018, 05:35 AM
Last Post: cooker
  Im having weird crashes on a new rock64 [solved] Trash_Can_Man 4 6,507 02-06-2018, 04:06 AM
Last Post: a1w.ca
Lightbulb MPP+DRM: low level API for video codecs and display (also 4k UHD+HDR+HLG) mcerveny 0 3,046 01-27-2018, 11:23 AM
Last Post: mcerveny
Information Solved - Resize Root Filesystem (Xenial) aussiemate 4 7,948 08-29-2017, 03:43 PM
Last Post: fbms
