Write SPI Flash don't work
(05-04-2018, 07:24 PM)t4_4t Wrote: From this, I guess that "cards with higher grade are more prone to problems."
However, it is not a problem of the card itself,
a problem with the "ROCK64" side including the driver.
The point that pointed out your log in the previous report means the above.
"Your-EVO" is "fall-back" to 25MHz after failure occurred at initialization.
This is "Card-A)" below, it is far below the performance of the original card.
And that is probably a problem on the "ROCK64" side, not doubting your card.
I think it's a bit chicken and the egg... I believe the issue is actually to do with the memory, as 0.6.28, which is the first of the images to fail to boot, and also sends the CPU into a bit of a thermal runaway, was the first build to introduce the change in DDR speed. The MMC / microSD failure may just be a red herring that resulted from issues further up the chain. rock64 boards shipped with two different speed grades of DDR, depending on cost. I have the pre-production v1.1, and also a first batch v2.0 production board, so they could have different speed RAM to your boards. The reports on the github issue tracker about kernel updates resulting in broken images may or may not also related.
Thanks for trying though. Hopefully we'll hear from ayufan or xalius, who should be able to shed some light on what the issue is.
Write SPI Flash don't work - by djukonline - 04-29-2018, 01:09 PM
RE: Write SPI Flash don't work - by vincent37 - 04-29-2018, 01:25 PM
RE: Write SPI Flash don't work - by djukonline - 04-29-2018, 02:11 PM
RE: Write SPI Flash don't work - by vincent37 - 04-29-2018, 02:56 PM
RE: Write SPI Flash don't work - by pfeerick - 04-29-2018, 05:22 PM
RE: Write SPI Flash don't work - by djukonline - 04-30-2018, 02:39 PM
RE: Write SPI Flash don't work - by pfeerick - 05-01-2018, 03:53 AM
RE: Write SPI Flash don't work - by Luke - 05-01-2018, 04:07 AM
RE: Write SPI Flash don't work - by pfeerick - 05-02-2018, 02:53 AM
RE: Write SPI Flash don't work - by djukonline - 05-02-2018, 12:29 PM
RE: Write SPI Flash don't work - by t4_4t - 05-02-2018, 10:33 PM
RE: Write SPI Flash don't work - by pfeerick - 05-03-2018, 03:48 AM
RE: Write SPI Flash don't work - by t4_4t - 05-03-2018, 05:15 AM
RE: Write SPI Flash don't work - by pfeerick - 05-03-2018, 04:11 PM
RE: Write SPI Flash don't work - by pfeerick - 05-04-2018, 04:46 AM
RE: Write SPI Flash don't work - by t4_4t - 05-04-2018, 07:24 PM
RE: Write SPI Flash don't work - by pfeerick - 05-04-2018, 08:47 PM
RE: Write SPI Flash don't work - by t4_4t - 05-05-2018, 08:44 AM
RE: Write SPI Flash don't work - by pfeerick - 05-05-2018, 08:10 PM
RE: Write SPI Flash don't work - by t4_4t - 05-05-2018, 11:58 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,407 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  HDMI doesn't work on rock64 Noung1991 1 658 11-21-2023, 08:33 AM
Last Post: as365n4
Sad HDMI doesn't work on rock64 rock7 0 2,820 12-16-2019, 01:04 PM
Last Post: rock7
Bug mpph264enc output doesn't work on bionic rompelstompel 11 16,867 11-15-2019, 10:00 AM
Last Post: gounthar
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 6,939 05-26-2019, 10:28 PM
Last Post: Wizardknight
  Cannot make DAC Add-on Board work under debian szclsya 0 1,893 09-29-2018, 12:57 AM
Last Post: szclsya
  Tutorial How to write a image in the eMMc card without USB adaptor or serial cable gedas07 2 3,865 08-29-2018, 10:08 AM
Last Post: gedas07
  If installing free software system which devices will not work? heocb 6 6,972 08-17-2018, 09:42 AM
Last Post: heocb
  Does AP w/ hostapd with official wifi dongle work? Arsiesys 5 7,233 01-17-2018, 04:03 AM
Last Post: Luke
  H264 hardware encoder not work sueshieh 3 6,575 11-02-2017, 03:57 AM
Last Post: dalmate
