Ethernet Slow Download
#55
(07-18-2016, 01:47 PM)amc2012 Wrote:
(07-18-2016, 01:45 PM)androsch Wrote:
(07-18-2016, 12:26 PM)xalius Wrote: PS: It is by no means sure that tuning the delays will fix all the GbE issues people seem to have, I had two working boards that can get around 800Mbit/s in both directions with the default values (tx-delay 3, rx-delay 0).... BUT I can degrade my performance substantially when I move away from those values, up to a point where the GbE stops working, so testing this on a board that doesnt work with the default will be interesting...
Not to stop anybody trying this also, i played around with my board (BTW tested by longsleep with his network and working fine there) not working with GB-lan, but got no improvement, just worse transfer rates. Only thing that helped was setting it to a fixed 100mb port. So i'm in doubt this will fix the problems many people having here with the network speed in GB-lan....
jm2c
Androsch
Are you saying you sent your board to longsleep and GbE is working totally fine in his environment??
Yep, he got my board and it worked fine in his environment, so it is not only a software issue, there must be something else on the hardware side to prevent the Pine64+ board from fuull speed GB. I tried several routers in my network and all work fine with other GB-lan hosts, but not with the Pine64+ (even in longsleeps network it worked fine)
Sounds weird, but thats the actual situation....
Androsch
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
Ethernet Slow Download - by Ascotg - 04-09-2016, 01:15 PM
RE: Ethernet Slow Download - by Roverius - 04-09-2016, 04:27 PM
RE: Ethernet Slow Download - by rahlquist - 04-10-2016, 12:17 AM
RE: Ethernet Slow Download - by teke - 04-25-2016, 04:21 AM
RE: Ethernet Slow Download - by utdrmac - 04-27-2016, 01:47 PM
RE: Ethernet Slow Download - by utdrmac - 04-27-2016, 03:10 PM
RE: Ethernet Slow Download - by piahoo - 04-28-2016, 01:04 PM
RE: Ethernet Slow Download - by utdrmac - 04-27-2016, 06:06 PM
RE: Ethernet Slow Download - by teke - 04-28-2016, 05:09 AM
RE: Ethernet Slow Download - by malevolent - 05-08-2016, 01:14 PM
RE: Ethernet Slow Download - by tkaiser - 05-09-2016, 04:33 AM
RE: Ethernet Slow Download - by utdrmac - 05-09-2016, 05:50 AM
RE: Ethernet Slow Download - by tkaiser - 05-09-2016, 06:06 AM
RE: Ethernet Slow Download - by pinecone - 05-12-2016, 12:23 PM
RE: Ethernet Slow Download - by luggi - 05-14-2016, 11:29 AM
RE: Ethernet Slow Download - by rahlquist - 05-14-2016, 08:36 PM
RE: Ethernet Slow Download - by dR@G - 05-15-2016, 07:05 AM
RE: Ethernet Slow Download - by luggi - 05-18-2016, 01:13 PM
RE: Ethernet Slow Download - by trinitytest - 05-21-2016, 06:22 PM
RE: Ethernet Slow Download - by williamsoro - 05-26-2016, 06:27 PM
RE: Ethernet Slow Download - by cpacheco - 06-10-2016, 03:15 PM
RE: Ethernet Slow Download - by amc2012 - 06-10-2016, 09:56 PM
RE: Ethernet Slow Download - by psmacmur - 06-12-2016, 09:19 AM
RE: Ethernet Slow Download - by cdslashetc - 06-29-2016, 01:09 PM
RE: Ethernet Slow Download - by Er0l - 07-01-2016, 04:17 PM
RE: Ethernet Slow Download - by AVL2016 - 07-10-2016, 12:11 AM
RE: Ethernet Slow Download - by Er0l - 07-10-2016, 01:27 AM
RE: Ethernet Slow Download - by AVL2016 - 07-10-2016, 08:47 AM
RE: Ethernet Slow Download - by cdslashetc - 07-10-2016, 10:40 AM
RE: Ethernet Slow Download - by amc2012 - 07-11-2016, 02:16 PM
RE: Ethernet Slow Download - by coleshores - 07-11-2016, 02:34 PM
RE: Ethernet Slow Download - by amc2012 - 07-11-2016, 02:56 PM
RE: Ethernet Slow Download - by utdrmac - 07-11-2016, 03:14 PM
RE: Ethernet Slow Download - by Summons - 07-11-2016, 06:00 PM
RE: Ethernet Slow Download - by coleshores - 07-11-2016, 06:03 PM
RE: Ethernet Slow Download - by utdrmac - 07-17-2016, 05:17 PM
RE: Ethernet Slow Download - by cdslashetc - 07-11-2016, 06:25 PM
RE: Ethernet Slow Download - by xalius - 07-11-2016, 06:34 PM
RE: Ethernet Slow Download - by amc2012 - 07-11-2016, 07:18 PM
RE: Ethernet Slow Download - by cdslashetc - 07-11-2016, 07:56 PM
RE: Ethernet Slow Download - by amc2012 - 07-11-2016, 08:30 PM
RE: Ethernet Slow Download - by xalius - 07-17-2016, 05:11 PM
RE: Ethernet Slow Download - by waldo - 07-17-2016, 05:34 PM
RE: Ethernet Slow Download - by Summons - 07-18-2016, 07:51 AM
RE: Ethernet Slow Download - by xalius - 07-18-2016, 08:01 AM
RE: Ethernet Slow Download - by waldo - 07-18-2016, 08:09 AM
RE: Ethernet Slow Download - by cdslashetc - 07-18-2016, 09:08 AM
RE: Ethernet Slow Download - by amc2012 - 07-18-2016, 09:15 AM
RE: Ethernet Slow Download - by Summons - 07-18-2016, 10:58 AM
RE: Ethernet Slow Download - by xalius - 07-18-2016, 12:26 PM
RE: Ethernet Slow Download - by androsch - 07-18-2016, 01:45 PM
RE: Ethernet Slow Download - by amc2012 - 07-18-2016, 01:47 PM
RE: Ethernet Slow Download - by androsch - 07-18-2016, 01:55 PM
RE: Ethernet Slow Download - by amc2012 - 07-18-2016, 02:03 PM
RE: Ethernet Slow Download - by nSkaarup - 08-06-2016, 09:27 AM
RE: Ethernet Slow Download - by longsleep - 07-18-2016, 02:05 PM
RE: Ethernet Slow Download - by amc2012 - 07-18-2016, 03:06 PM
RE: Ethernet Slow Download - by Summons - 07-19-2016, 06:46 AM
RE: Ethernet Slow Download - by cdslashetc - 07-20-2016, 01:47 PM
RE: Ethernet Slow Download - by cdslashetc - 07-21-2016, 03:59 AM
RE: Ethernet Slow Download - by cdslashetc - 07-22-2016, 05:44 PM
RE: Ethernet Slow Download - by cdslashetc - 07-22-2016, 06:44 PM
RE: Ethernet Slow Download - by cdslashetc - 07-23-2016, 11:42 AM
RE: Ethernet Slow Download - by waldo - 07-24-2016, 01:27 PM
RE: Ethernet Slow Download - by cdslashetc - 07-24-2016, 02:26 PM
RE: Ethernet Slow Download - by waldo - 08-01-2016, 08:03 PM
RE: Ethernet Slow Download - by dkryder - 07-24-2016, 02:02 PM
RE: Ethernet Slow Download - by cdslashetc - 08-06-2016, 11:55 AM
RE: Ethernet Slow Download - by amc2012 - 08-06-2016, 12:13 PM
RE: Ethernet Slow Download - by MarkHaysHarris777 - 08-06-2016, 01:10 PM
RE: Ethernet Slow Download - by amc2012 - 08-06-2016, 04:40 PM
RE: Ethernet Slow Download - by MarkHaysHarris777 - 08-06-2016, 05:25 PM
RE: Ethernet Slow Download - by amc2012 - 08-06-2016, 05:46 PM
RE: Ethernet Slow Download - by MarkHaysHarris777 - 08-06-2016, 07:20 PM
RE: Ethernet Slow Download - by amc2012 - 08-06-2016, 07:52 PM
RE: Ethernet Slow Download - by cdslashetc - 08-06-2016, 08:05 PM
RE: Ethernet Slow Download - by waldo - 08-06-2016, 08:23 PM
RE: Ethernet Slow Download - by amc2012 - 08-06-2016, 08:30 PM
RE: Ethernet Slow Download - by waldo - 08-06-2016, 08:38 PM
RE: Ethernet Slow Download - by cdslashetc - 09-04-2016, 08:55 AM
RE: Ethernet Slow Download - by androsch - 09-04-2016, 09:48 AM
RE: Ethernet Slow Download - by tllim - 09-07-2016, 05:00 PM
RE: Ethernet Slow Download - by androsch - 09-08-2016, 11:34 AM
RE: Ethernet Slow Download - by MarkHaysHarris777 - 09-08-2016, 11:58 AM
RE: Ethernet Slow Download - by androsch - 09-08-2016, 12:21 PM
RE: Ethernet Slow Download - by waldo - 09-08-2016, 01:05 PM
RE: Ethernet Slow Download - by cdslashetc - 09-08-2016, 01:07 PM
RE: Ethernet Slow Download - by MarkHaysHarris777 - 09-08-2016, 01:50 PM
  Ethernet port down afert 1 day jeda 0 671 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 5,388 05-16-2017, 03:41 AM
Last Post: m17
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 24,927 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 16,721 10-17-2016, 03:42 PM
Last Post: waldo
  Pine64+ 1GB Ethernet Port spec ecotack 13 16,001 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,415 08-17-2016, 05:44 PM
Last Post: MarkHaysHarris777
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 6,215 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
