Ethernet port down afert 1 day
I have bought 2 Pine A64+ from Ibood last week.
One of the boards has some trouble with the ethernet connection.
Everything worked just fine, but after 1 day, the network connection was dropped and my board was not accessible anymore.
This is my setup:
Serial number : 410640172333
OS : DietPi
Installed software : Webmin, docker, docker-compose
I have tried a new microsd card with a fresh installation of DietPi, but at the installation the system is complaining that there is no internet connection.
I also switched the microsd card with the one that works on the other board.
I have tried a different switch, network cabel, power supply, DHCP / static ip.
Switched the network speed to 100.
But nothing did the trick.
My network contoller (Unifi) says there is a device connected, but the device is not accesible
Ibood says i have to take contact by this forum.
So my question is, what can i do to make everything work again.
Kind regards,
Jelle
  Ethernet --> Causing boot loop podtofs 3 5,333 05-16-2017, 03:41 AM
Last Post: m17
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 24,648 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 16,536 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 113,999 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 15,782 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,390 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 6,144 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
