My first Single Board!
(04-05-2018, 08:16 PM)jjh221 Wrote: Hey guys after a lengthy search for my first single board I settled on the Rock64 mostly because of the 4gb ram. I wish that it had wifi but a dongle works just as well and gives it a little more character. Anyways I just wanted to say hey and thank you for this board.
It has been many years since I have used linux so I have some reading to do tonight. The wiki seems very informative. Smile Also I have some future plans to bring many more people into the single board world and I hope that this community will help and welcome them.
I do have one question right now. I flashed my 64gb SD with jessie-minimal-rock64-0.5.15-136-arm64.img however it has no desktop enviroment. What is the easiest way for me to get a pretty looking and easy to use linux up and running quickly? Also security is a major issue. It must be safe.
Thanks,
J
If you want to use a desktop environment with your Rock64 then please follow this thread. At the end of this month ayufan is aiming to release a stable 0.6.X OS image based on Bionic which will come with LXDE. For now however, you need to install the desktop yourself.
Security isn't an issue.
My first Single Board! - by jjh221 - 04-05-2018, 08:16 PM
RE: My first Single Board! - by Luke - 04-06-2018, 02:46 AM
RE: My first Single Board! - by jjh221 - 04-07-2018, 02:06 PM
RE: My first Single Board! - by tllim - 04-09-2018, 04:02 PM
RE: My first Single Board! - by jjh221 - 04-09-2018, 06:52 PM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,591 10-06-2022, 08:46 PM
Last Post: ihab
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,546 05-15-2019, 02:55 PM
Last Post: Thatoo
  sopine cluster board install Smurfbot 1 4,420 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 3,542 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 2,296 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 8,878 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 3,257 01-15-2018, 11:21 AM
Last Post: Luke
  What is on the Micro SC card that came with the board? clawinus 1 3,700 11-03-2016, 02:33 PM
Last Post: MarkHaysHarris777
  Power Switch for Pine64 512MB Board MonarchOfLight 0 2,550 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
  PineA64 512 reboot - board shut down indrajith 7 12,686 07-28-2016, 02:07 PM
Last Post: Ghost
