ADB support
have you gone to the playstore and searched for adb & fastboot? those apps will install adb and fastboot on the device itself. you can also search google for adb on device and you will be linked to some that are not in playstore however i think that the adb dameon is quite old however xda has links to 2.0 insecure
https://forum.xda-developers.com/showthr...?t=1687590. and really, if you say adb over network like in your first post you are not using adbd to do that. you meant adb local to the device, which btw requires root. there is also adb via wireless.
ADB support - by krystian - 02-22-2018, 12:39 PM
RE: ADB support - by a1w.ca - 02-23-2018, 01:00 AM
RE: ADB support - by krystian - 02-23-2018, 01:10 AM
RE: ADB support - by dkryder - 02-23-2018, 12:43 PM
RE: ADB support - by krystian - 02-23-2018, 02:42 PM
RE: ADB support - by dkryder - 02-23-2018, 04:46 PM
RE: ADB support - by JeffsNetflixPassword - 03-06-2018, 12:08 PM
  Does “0.2.14: jenkins-android-7.1-rock-64-69” support wifi? fbms 5 6,956 10-18-2017, 07:50 AM
Last Post: Guy the IT Guy
