u-boot on SPI: USB boot partition
It is a bit different for every ARM SoC, but usually there is a boot ROM in the hardware that looks for a valid boot device (sdcard, emmc, spi-flash, nand...), then there is a second stage loader (SPL - from u-boot or other source) on the image that initializes DRAM and loads the ATF (ARM Trusted Firmware) and u-boot from the image, u-boot then usually does some more hardware initialization if necessary and then loads your devicetree, initrd, kernel from the image to boot whatever OS you have... how you structure the image wrt to firmware location and partition layout is dependent on the first stage boot ROM and how you configure u-boot as well as what your OS requires, the FAT partition is more a convenience thing for Windows users so they can access some config files, it is not strictly necessary...
You can find more details how RK3328 boot in the technical reference manual (http://opensource.rock-chips.com/images/...170321.pdf) and by looking at ayufan's github for the sources of u-boot, linux and the image build system, also the sources for the u-boot on the SPI flash: http://www.github.com/ayufan-rock64
u-boot on SPI: USB boot partition - by prof7bit - 02-12-2018, 10:20 AM
RE: u-boot on SPI: USB boot partition - by xalius - 02-12-2018, 03:08 PM
  Rock64 won't boot luminosity7 10 4,439 03-16-2024, 08:33 AM
Last Post: dmitrymyadzelets
  Rock64 doesn't boot dstallmo 1 399 03-16-2024, 08:29 AM
  Boot from SPI first mjnck 1 1,594 02-29-2024, 02:12 PM
Last Post: reukiodo
  ROCK64 v3 can it boot from USB? Tsagualsa 4 2,214 11-29-2022, 11:31 AM
Last Post: Macgyver
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 1,103 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  boot hdd usb3 philipe 1 2,724 01-27-2021, 02:12 PM
  Libreelec Rock64 - 4GB no boot spiker15 3 4,680 11-02-2020, 12:36 AM
Last Post: wilsonYan
  Rock64 - boot helpmerock 2 3,622 10-08-2020, 01:29 PM
Last Post: helpmerock
  No boot up after power on Whoopsadaisy 4 5,785 09-26-2020, 05:14 PM
Last Post: simonsouth
Bug u-boot (forks) status mcerveny 14 15,695 08-27-2020, 01:44 PM
Last Post: globaltree
