SoPine SPI booting
#19
Smile
(05-07-2018, 02:10 AM)hexalyn Wrote: You want me to give a try to modify a bit ayufan's scripts to release a new image to flash mainline u-boot in the SPI ?
@aww : Thanks a lot for your efforts !
@aww : here is a version using Ayufan's scripts with mainline u-boot : https://transfer.sh/4h6rM/u-boot-mainlin...spi.img.xz
Could you try it and tell me if it works as expected ? I had no issues with any command not found. What command was it ?
Thanks for generating that (and the previous image, although I haven't gotten around to trying it... should do that right now just for giggles...)
The image boots, but it fails to erase or write to the SPI... that sf command must be something to do interacting with the spi flash...
https://pastebin.com/VUJtee2b
I'll boot the image up again with network connected and see if it actually pokes the ethernet... it looks promising as it did indicate phy negotiation was complete. I'll run through that, and add a second boot log or comment shortly...
A little later...
Well, I booted the pine64 master box up, and watching the log from dnsmasq (sudo tailf /var/log/syslog | grep dnsmasq-dhcp), I was starting to get
May  4 06:39:33 localhost dnsmasq-dhcp[1246]: 154664209 available DHCP subnet: 192.168.0.0/255.255.255.0
May  4 06:39:33 localhost dnsmasq-dhcp[1246]: 154664209 vendor class: U-Boot.armv8
repeated endlessly once the sopine got it's act together and was doing the BOOTP broadcast, so networking is indeed working, and it is trying! Smile
Also, sudo tcpdump -i eth0 port 67 or port 68 -e -n was giving me
06:45:08.378427 02:ba:09:37:bd:8b > ff:ff:ff:ff:ff:ff, ethertype IPv4 (0x0800), length 342: 0.0.0.0.68 > 255.255.255.255.67: BOOTP/DHCP, Request from 02:ba:09:37:bd:8b, length 300
And at some point, also got some
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 available DHCP subnet: 192.168.0.0/255.255.255.0
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 vendor class: PXEClient:Arch:00011:UNDI:003000
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 PXE(eth0) 02:ba:09:37:bd:8b proxy
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 tags: eth0
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 broadcast response
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 sent size:  1 option: 53 message-type  2
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 sent size:  4 option: 54 server-identifier  192.168.0.250
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 sent size:  9 option: 60 vendor-class  50:58:45:43:6c:69:65:6e:74
May  4 06:40:19 localhost dnsmasq-dhcp[1246]: 154710342 sent size: 29 option: 43 vendor-encap  06:01:08:0a:17:05:42:6f:6f:74:69:6e:67:20...
happening also... did somebody say PXE? :-D
So getting warmer! And btw, the older earlier image writes the SPI flash properly, but the ethernet doesn't work. So it looks like mainline may be the best way for now if we can get uboot on the spi flash...
SoPine SPI booting - by ayufan - 01-16-2018, 03:31 AM
RE: SoPine SPI booting - by hexalyn - 01-23-2018, 09:29 AM
RE: SoPine SPI booting - by ayufan - 01-23-2018, 01:06 PM
RE: SoPine SPI booting - by aww - 02-14-2018, 10:13 PM
RE: SoPine SPI booting - by pfeerick - 05-04-2018, 12:33 AM
RE: SoPine SPI booting - by hexalyn - 05-04-2018, 03:35 AM
RE: SoPine SPI booting - by pfeerick - 05-04-2018, 06:01 AM
RE: SoPine SPI booting - by hexalyn - 05-04-2018, 07:04 AM
RE: SoPine SPI booting - by aww - 05-04-2018, 08:56 AM
RE: SoPine SPI booting - by hexalyn - 05-04-2018, 09:18 AM
RE: SoPine SPI booting - by aww - 05-04-2018, 09:37 AM
RE: SoPine SPI booting - by hexalyn - 05-04-2018, 09:46 AM
RE: SoPine SPI booting - by aww - 05-04-2018, 10:59 AM
RE: SoPine SPI booting - by aww - 05-05-2018, 12:34 PM
RE: SoPine SPI booting - by aww - 05-05-2018, 06:36 PM
RE: SoPine SPI booting - by aww - 05-05-2018, 08:20 PM
RE: SoPine SPI booting - by hexalyn - 05-07-2018, 02:10 AM
RE: SoPine SPI booting - by pfeerick - 05-08-2018, 02:44 AM
RE: SoPine SPI booting - by aww - 05-07-2018, 08:17 AM
RE: SoPine SPI booting - by hexalyn - 05-08-2018, 03:46 AM
RE: SoPine SPI booting - by aww - 05-17-2018, 03:14 PM
RE: SoPine SPI booting - by pfeerick - 05-18-2018, 03:48 AM
RE: SoPine SPI booting - by jcw - 01-22-2019, 03:34 AM
RE: SoPine SPI booting - by jgullickson - 01-17-2020, 03:55 PM
RE: SoPine SPI booting - by Pine - 10-30-2020, 07:33 PM
RE: SoPine SPI booting - by mundey - 02-05-2023, 10:17 PM
RE: SoPine SPI booting - by mundey - 02-13-2023, 08:56 PM
RE: SoPine SPI booting - by lbruno - 05-11-2020, 12:46 PM
RE: SoPine SPI booting - by Pine - 11-01-2020, 07:00 PM
RE: SoPine SPI booting - by lbruno - 12-15-2020, 05:12 PM
RE: SoPine SPI booting - by Pine - 03-10-2021, 10:33 AM
RE: SoPine SPI booting - by poVoq - 09-26-2022, 06:39 AM
  slarm64 (unofficial slackware) SOPINE A64 (aarch64) mara 6 3,914 09-24-2023, 11:43 AM
  Sopine Fedora 32 on clusterboard w/networking revoman 7 9,530 04-10-2023, 08:49 AM
Last Post: langerma
  Try to boot armbian 22.02 on SoPine baseboard adjivas 1 993 01-11-2023, 03:20 PM
Last Post: MNtinkerer
  sopine-a64 yocto build running on SOPine Baseboard tderensis 1 1,476 07-13-2022, 03:14 PM
Last Post: tderensis
  Volumio (PINE A64-LTS / SOPINE) pineadmin 7 9,502 02-17-2021, 03:47 AM
Last Post: roel
  SOPINE Network boot Ninazu 1 3,866 05-11-2020, 12:40 PM
Last Post: lbruno
  LibreELEC(KODI) for LTS/ SOPine pineadmin 2 5,744 12-27-2019, 11:09 PM
  Armbian - Xenial (SOPINE) pineadmin 6 14,451 08-05-2019, 01:17 AM
Last Post: pineadmin
  Sopine baseboard / A64 base board as OTG mixotricha 0 2,640 07-08-2019, 07:11 PM
Last Post: mixotricha
  NEMS Linux for LTS/ SOPine Luke 1 4,099 05-09-2019, 05:46 PM
