USB 3.0 Host Controller crashes when accessing several devices simultaneously
You need to make sure that you get SATA/USB3 bridges that have no quirks/bugfixes already enabled in the Linux kernel, otherwise UAS or other features might be disabled. Armbian and others did some tests and generally the JMS576/JMS578 seem to work well. Is this with BSP or mainline kernel? You could also file an issue with your description against Rockchip's kernel on github if it is a BSP based image...
RE: USB 3.0 Host Controller crashes when accessing several devices simultaneously - by xalius - 01-11-2018, 04:22 PM
  How Can Install Unify controller in rock64? gedas07 0 1,876 03-23-2020, 08:41 AM
Last Post: gedas07
  If installing free software system which devices will not work? heocb 6 7,032 08-17-2018, 09:42 AM
Last Post: heocb
  virtual machine, arm host kwarren 1 3,213 08-06-2018, 05:26 PM
Last Post: hiccupstix
  Im having weird crashes on a new rock64 [solved] Trash_Can_Man 4 6,568 02-06-2018, 04:06 AM
Last Post: a1w.ca
  Unifi Controller lightning 2 4,206 10-19-2017, 07:42 AM
Last Post: lightning
  My Board keeps crashing on startup, no USB devices conected Ptheven 0 1,697 09-19-2017, 10:29 AM
Last Post: Ptheven
