Unifi Controller
Does anybody have Unifi controller working on Rock64?
If possible a guide work be really helpful for me, thanks in advance.
https://help.ubnt.com/hc/en-us/articles/...-or-Ubuntu maybe dunno.
At the moment Ubiquiti does not support arm64, hence it is not available via the repo. A download and manual installation will be necessary. The bundled snappy-java package in versions 5.5.x and previous, do not support arm64. In v5.6.1 Unstable (might be reverted for 5.6.2) that changed to an updated snappy-java package. That being said, the following script can be run after install to update the bundled version, which should help it ru
(10-18-2017, 06:06 PM)stuartiannaylor Wrote: https://help.ubnt.com/hc/en-us/articles/...-or-Ubuntu maybe dunno.
Thank you, I will give it a try and feedback.
  How Can Install Unify controller in rock64? gedas07 0 1,851 03-23-2020, 08:41 AM
Last Post: gedas07
  USB 3.0 Host Controller crashes when accessing several devices simultaneously h31 10 17,296 11-10-2018, 07:26 PM
Last Post: Trash_Can_Man
