(SO)Pine64 Clusterboard
Edit 6: 2017/12/21
While running cpuburn-a53 on all nodes to check out the stability of the system, I also added the two 80mm x 80mm fans... those are needed under full continuous load to prevent frequency throttling of the cores.
80x80mm fans with 2000RPM@12V/0.13A
I need to come up with some fan mounts and maybe some air duct or chimney...
After the tests with cpuburn-a53 I put together a quick distcc cluster setup with one node as master and 6 slaves to build a linux kernel. The time for a build (only Image) went from about 24 minutes on one node to about 7 minutes with the distcc setup... the workload on the nodes was pretty uneven during that build and there is a lot written on how to improve distcc with load-balancing... for comparison my old Thinkpad (i7-2720QM CPU @ 2.20GHz, 32GB RAM, 850PRO SSD) takes about 4 minutes to cross-compile this kernel...
(SO)Pine64 Clusterboard - by xalius - 12-15-2017, 03:54 PM
RE: (SO)Pine64 Clusterboard - by dkryder - 12-16-2017, 06:09 AM
RE: (SO)Pine64 Clusterboard - by xalius - 12-20-2017, 05:39 PM
RE: (SO)Pine64 Clusterboard - by xalius - 12-21-2017, 02:25 PM
RE: (SO)Pine64 Clusterboard - by maya.b - 12-28-2017, 01:38 PM
RE: (SO)Pine64 Clusterboard - by Luke - 12-28-2017, 05:00 PM
RE: (SO)Pine64 Clusterboard - by maya.b - 12-29-2017, 02:21 AM
RE: (SO)Pine64 Clusterboard - by maya.b - 12-29-2017, 02:23 PM
RE: (SO)Pine64 Clusterboard - by tllim - 12-29-2017, 08:11 PM
RE: (SO)Pine64 Clusterboard - by tllim - 12-31-2017, 08:03 PM
RE: (SO)Pine64 Clusterboard - by zdeneksejcek - 01-04-2018, 02:37 AM
RE: (SO)Pine64 Clusterboard - by tllim - 01-04-2018, 10:55 AM
RE: (SO)Pine64 Clusterboard - by hexalyn - 01-23-2018, 09:34 AM
RE: (SO)Pine64 Clusterboard - by tllim - 01-29-2018, 11:09 PM
RE: (SO)Pine64 Clusterboard - by cristipurdel - 01-28-2018, 10:58 AM
RE: (SO)Pine64 Clusterboard - by xalius - 01-10-2018, 11:40 AM
RE: (SO)Pine64 Clusterboard - by bergera - 01-30-2018, 08:17 AM
RE: (SO)Pine64 Clusterboard - by bristolisopen - 01-30-2018, 10:59 AM
RE: (SO)Pine64 Clusterboard - by xalius - 01-30-2018, 12:36 PM
RE: (SO)Pine64 Clusterboard - by bergera - 02-05-2018, 03:20 PM
RE: (SO)Pine64 Clusterboard - by hexalyn - 02-06-2018, 03:39 AM
RE: (SO)Pine64 Clusterboard - by cristipurdel - 02-09-2018, 02:42 AM
RE: (SO)Pine64 Clusterboard - by hexalyn - 02-09-2018, 02:57 AM
RE: (SO)Pine64 Clusterboard - by www139 - 05-16-2018, 03:45 PM
RE: (SO)Pine64 Clusterboard - by evilbunny - 05-16-2018, 04:38 PM
RE: (SO)Pine64 Clusterboard - by pfeerick - 05-17-2018, 02:28 AM
  Managed Ethernet switch on the Clusterboard dsimic 6 5,732 01-16-2024, 02:05 AM
Last Post: hazcam
  Selling Clusterboard + 4 sopine xblack86 7 6,067 09-26-2022, 03:09 AM
Last Post: poVoq
  clusterboard availability? linear 1 1,698 07-17-2022, 06:44 AM
Last Post: poVoq
  Clusterboard not getting IP address after network fix Norlark 14 12,965 08-30-2021, 05:00 PM
Last Post: poVoq
  When would be the Clusterboard back on stock? __kzl__ 5 5,409 08-16-2021, 03:52 AM
Last Post: poVoq
  Schematics for customising the Clusterboard TechDragon 0 2,131 05-25-2021, 10:28 AM
Last Post: TechDragon
Information Clusterboard Guide AZClusterboard 9 23,647 04-06-2021, 06:32 AM
Last Post: poVoq
Brick Clusterboard CAD drawings TeaPack 1 3,892 03-31-2021, 01:38 PM
Last Post: Pine
  New Clusterboard Setup wargfn 5 7,496 01-01-2021, 10:10 AM
Last Post: poVoq
  Clusterboard does not even turn on? poVoq 3 6,329 08-15-2020, 07:31 AM
Last Post: poVoq
