How to set the Power Off key binding in i3wm for the Pinebook
Information
Greetings,
The purpose of this blog post is to detail the steps necessary to set the Power Off key-binding for the Pinebook in i3 window manager.  We don't want the Pinebook to come crashing down if we accidentally touch the poweroff button -- so we'll set a key-binding that makes sense requiring at least two other keys , for instance the $mod key and the Shift key.  The following key-binding should bring the system down cleanly ( and power off properly ) without prompting for a password:
       $mod+Shift+XF86_PowerOff
The key-binding will be placed in the i3 config;  but I'm getting ahead of myself.  The first step is to build the poweroff script in /usr/local/sbin/
Pb_poweroff.sh
#!/bin/sh
poweroff
The simple script above should be placed in  /usr/local/sbin/  and should be made active with the following commands:
       sudo  chown  root:root  Pb_poweroff.sh
       sudo  chmod  0754  Pb_poweroff.sh
The next step is to place a rule file in  /etc/sudoers.d/  so that the command trigger will not prompt for the sudo password when the key-binding is pressed.  Creat the following rule file in /etc/sudoers.d/  :
Pb_power_rule
# Pb power rule
Cmnd_Alias PBPOWEROFF=/usr/local/sbin/Pb_poweroff.sh
ALL ALL=NOPASSWD: PBPOWEROFF
Place the above rule file in the  /etc/sudoers.d/  directory and activate with the following commands :
       sudo  chown  root:root  Pb_power_rule
       sudo  chmod  0440  Pb_power_rule
The last step is to place the following bindsym entry in the i3 configuration  ~/.config/i3/config  , in your home directory:
       bindsym  $mod+Shift+XF86_PowerOff  exec  sudo  /usr/local/sbin/Pb_poweroff.sh
Place the above bindsym entry somewhere near the end of your i3 config after the "resize"  and before the "bar".  The configuration file is  ~/.config/i3/config
Activate the key-binding by either pressing $mod+Shift+c to re-read the config,  or $mod+Shift+r to restart i3wm.
Theory
Pressing the Pinebook power button returns scancode 124;  key-sym XF86_PowerOff.  This by default does nothing in i3wm;  unlike other OS window manager | desktops  ,  which typically pulls up the shutdown dialogue.
With our keybinding in effect the Pb_poweroff.sh script will be called with sudo,  and because the Pb_power_rule file exists in /etc/sudoers.d/  the command trigger will not prompt for the password,  but the poweroff command will simply take effect:   while holding down the mod key,  and the Shift key together,  press the power button and the i3 window manager will exit and the system will cleanly shutdown and power off.
Shy
How to set the Power Off key binding in i3wm for the Pinebook - by MarkHaysHarris777 - 09-16-2017, 10:21 PM
  DietPi OS for Pinebook MichaIng 3 5,526 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,651 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 957 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 746 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,849 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,278 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,939 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,314 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,854 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,826 12-25-2020, 04:40 PM
Last Post: ford442
