The 6 most common reasons why Pine64 won't boot
#47
(04-30-2016, 02:07 AM)romangaag Wrote: Hello! I have problems with my pine64 also. My conf:
2 GB with BT+Wifi module installed
5V 2A adapter (tried several different)
NO Ethernet cable connected.
Direct HDMI to Phillips TV 1920 x 1080
64 GB SDXC
I was very-very careful about static, so the board is ok.
What do I have. I've tried to installed both Android (all 3 images) and Remix OS using PhoenixCard.
RemixOS has been installed (it was not easy, but installed at the end). But when it boots up it works EXTREMELY slow (reacts in 10-15 secs after pushing "start"-button), shows black screen, error messages (ex "Process system isn't responding. Do you want to close it?") and reboots.
Thereafter it may boot or not (depands on I have no idea what).
Android OS did not boot up at all. First it shows up "Powered by Android"-screen, then just PINE64 logo and that's it.
Any ideas? :-)
p.s. Photoes:
1. Stucked RemixOS
https://drive.google.com/open?id=0B5Vj6H...0RmcEt1THM
2. RemixOS message
https://drive.google.com/open?id=0B5Vj6H...jNlTmR1RDQ
3. Androis start screen (lasts for 30-40 secs)
https://drive.google.com/open?id=0B5Vj6H...VZwNndFdW8
4. Then I see Pine64 logo
https://drive.google.com/open?id=0B5Vj6H...WFZZmFoZTA
5. My board
https://drive.google.com/open?id=0B5Vj6H...EdVM1FxM2c
Looks like microSD card access issue. I have similar experience using on SanDisk 64GB microSD card, and the problem goes away when switch to other card.
RE: The 6 most common reasons why Pine64 won't boot - by tllim - 04-30-2016, 02:20 AM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 245 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,310 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,742 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,621 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,747 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,814 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,544 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,226 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,307 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,194 10-18-2020, 01:41 PM
Last Post: toiny
