The 6 most common reasons why Pine64 won't boot
(03-31-2016, 10:42 AM)pine.tree Wrote: Add the common peripherals in first boot issue- mouse, keyboard, wifi dongle, whatever; shouldn't be plugged in while the board first boots up on a new image.
Nope, it's Ethernet. At least with the RemixOS image. If Ethernet is connected on the first boot then this will never happen and you see the Pine64 logo forever. If Ethernet is disconnected and you see the floating Remix OS logo then the kernel is taking over and you can safely insert Ethernet again.
So there is another bug regarding Ethernet only affecting 1st boot behaviour at least with RemixOS. It should be easy to verify this with the Android image and get back to this thread.
But this collection of missing informations is rather useless since the Pine64 folks happily refrain from using all this user collected information to create a FAQ that might save new users some time.  Angry
RE: The 5 most common reasons why Pine64 won't boot - by Andrew2 - 04-04-2016, 06:27 AM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 147 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,212 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,650 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,593 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,720 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,770 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,485 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,138 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,269 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,172 10-18-2020, 01:41 PM
Last Post: toiny
