The 6 most common reasons why Pine64 won't boot
#68
(06-07-2016, 08:24 PM)pcfr33k Wrote:
(06-07-2016, 09:23 AM)Ghost Wrote:
(06-07-2016, 09:18 AM)pcfr33k Wrote:
(06-07-2016, 04:24 AM)Luke Wrote:
(06-06-2016, 10:45 PM)pcfr33k Wrote: Tried different images, none boot.  Windows 10 Pro using Phoenix Card 3.1.0.  I chose startup option on the Phoenix Card software.  Allwinner processor starts to get hot and I have to remove power.   Is my board defective?  I just received it a couple days ago.  A64-DB -2G -Rev B dated 2106-03-21.
I am using HDMI so I burned the HDMI Android 5.1.1 release.  Also tried Remix OS same issue won't boot.
1) Burn a linux image
2) disconnect everything except for ethernet // power the Pine on
3) watch for LED activity on ethernet ports / see if the red power LED stays solid
4) see if you can ssh into the Pine
You can always swing by the chat - someone will help you troubleshoot.
Got it to work with a linux image burned on Windows 10 Pro using Win32DiskManager.  That needs to go on Wiki BTW.  Some people may not want to burn a Linux image in Linux!!
Now we need to know why RemixOS and Android 5.1.1 burned in Phoenix will not work.  Can I use Win32DIskManager to burn those images as well?
On the Pine64 Software Release part of the wiki, DD images are for Win32DiskImager and there are also images labelled as being for PhoenixCard.
RemixOS for PhoenixCard:
http://files.pine64.org/os/remix/remix-v...ixCard.zip
RemixOS for Win32DiskImager (8GB image):
http://files.pine64.org/os/remix/remix-v...64-8GB.zip
Android for PhoenixCard:
http://files.pine64.org/os/android/andro...ixCard.zip
Android for Win32DiskImager (8GB image):
http://files.pine64.org/os/android/andro...64-8GB.zip
Thanks.  I have the 32gb card so will any of those links work?  They all say 8gb?
My mistake I see 8 to 64gb in the links sorry about that.
Nope none work with 32Gb card.  Only ones that work are linux since they work on a range of the size of the card.  The links you listed are for the 8gb sdcard.  Do you have images of all those links for the 32gb card to burn with Win32DiskManager?
RE: The 6 most common reasons why Pine64 won't boot - by pcfr33k - 06-08-2016, 12:10 AM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 250 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,311 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,747 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,621 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,748 08-07-2022, 10:47 AM
Last Post: commiecam
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,816 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,544 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,229 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,307 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,196 10-18-2020, 01:41 PM
Last Post: toiny
