Shutdown / Restarting Android Rock64
Wondered about the recommended method of powering down Rock64 running Android. Found a post in the Pine64 section from 2016. Here's what I experienced.
1. Short press of the power button on Rock64 = blanks the screen. Short press a second time brings up the screen.
2. Long press of the power button on Rock64 = displays power off / restart dialog box. Defaults to power off, press Enter, Rock64 powers off. Arrow down to Restart, then Enter, Rock64 says powering down, and then it restarts.
3. Restarting via the settings menu (Settings - About - Restart) also restarts but I couldn't find anything in settings about shutting down.
4. Pressing the reset button on Rock64 = resets (probably not recommended, doesn't correctly close first, just hard reset like pulling the power?).
5. If off - pressing the power button = powers it up, pressing the reset button = powers it up.
I assume my results are by design. If not, best method for powering down?  Don't want to corrupt the eMMC. Thanks.
NOTE: base Android, not Android TV build. Not sure if the results would be the same.
Shutdown / Restarting Android Rock64 - by Farley56 - 09-15-2017, 09:15 AM
Shutdown / Restarting Android Rock64 - by w.otter - 10-05-2017, 04:41 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,353 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,082 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,599 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 169,176 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,048 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,530 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,077 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,598 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,766 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,882 09-09-2020, 08:44 AM
Last Post: BowerR64
