How to Configure Screen Brightness in mate on pinebook via terinal?
Thank you for the great advice @MarkHaysHarris777!
To get this work on my Pinebook (1080p - Arch image with i3) I had to change the file from  /sys/class/backlight/lcd0/brightness to /sys/class/backlight/backlight/brightness, the top value from 100 to 10  and the stepping to single digits. I'm not sure if this is due to the hardware or the os or both.
To get the max possible value: `cat /sys/class/backlight/backlight/max_brightness`
The script to raise the brightness then looks like this:
#!/bin/bash
LCDVALUE=`cat /sys/class/backlight/backlight/brightness`
NEWVALUE=$(( $LCDVALUE + 1 ))
if [ $NEWVALUE -le 10 ]
then
  echo $NEWVALUE > /sys/class/backlight/backlight/brightness
  echo $NEWVALUE
else
  echo $LCDVALUE
fi
and the one to decrease it (careful - this can completely dim the screen when the value gets to 0):
#!/bin/bash
NEWVALUE=$(( $LCDVALUE - 1 ))
if [ $NEWVALUE -ge 0 ]
then
  echo $NEWVALUE
else
  echo $LCDVALUE
fi
More info: https://wiki.archlinux.org/index.php/backlight
RE: How to Configure Screen Brightness in mate on pinebook via terinal? - by mikee3000 - 12-02-2018, 05:37 AM
  DietPi OS for Pinebook MichaIng 3 5,467 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,352 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 932 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 721 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,738 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,249 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,906 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,284 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,836 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,815 12-25-2020, 04:40 PM
Last Post: ford442
