(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
#92
(04-17-2016, 07:31 PM)lenny.raposo Wrote: the tar.gz are rootfs to be used with any kernel build you can come up with for th epine now the img.xz are teh fully images.
you must simply use something like 7zip to decompress teh file. Once decompressed you should have a full img to burn to sd card Wink
Thanks for the replay.
I found the following procedure, is it right?
umount /dev/sdb1
mkfs.ext3 /dev/sdb1
mount /dev/sdb1 /mnt/card
tar ‐xzvf filename.tar.gz ‐C /mnt/card
umount /dev/sdb1
I found the solution:
1) download the *.img.xz file
2) unzip with 7zip (or similar) and get the *.img file
3) mount with win32diskimager (or similar)
Thank again!
RE: Debian Image In The Works - by umiddelb - 03-30-2016, 01:58 AM
RE: Debian Image In The Works - by tllim - 03-30-2016, 02:08 AM
RE: Debian Image In The Works - by longsleep - 03-30-2016, 11:50 AM
RE: Debian Image In The Works - by Bargepole - 04-02-2016, 05:57 AM
RE: Debian Image In The Works - by Ghost - 04-03-2016, 07:55 PM
RE: Debian Image In The Works - by Bargepole - 04-04-2016, 12:35 AM
RE: Debian Image In The Works - by tnecniv102 - 05-01-2016, 09:36 AM
RE: Debian Image In The Works - by tkaiser - 05-01-2016, 10:27 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 02:35 AM
RE: Debian Image In The Works - by merriam - 04-05-2016, 09:26 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:57 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:18 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 01:13 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 12:36 PM
RE: Debian Image In The Works - by longsleep - 04-09-2016, 05:35 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 05:51 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 02:22 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 03:03 PM
RE: Debian Image In The Works - by rahlquist - 04-07-2016, 05:30 AM
RE: Debian Image In The Works - by rahlquist - 04-08-2016, 06:13 AM
Success with this... - by cbbrowne - 04-13-2016, 10:16 AM
RE: Debian Jessie Images (3.10.65 BSP Kernel) - by Informatica - 04-18-2016, 01:54 AM
issue with 2 ethernet lines - by dkryder - 07-03-2016, 03:31 AM
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,998 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 13,023 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 3,005 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,335 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 123,069 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,861 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,294 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,428 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,354 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 12,263 05-09-2018, 09:07 PM
Last Post: pfeerick
