(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
#26
The images are not the factor here as they work for others. There can be 4 possibilities here.
1) Faulty SD Card(s).
2) Faulty PC MMC Drive.
3) Premature ejection of disk before write is completely flushed to disk (likely in most cases).
4) Faulty Pine64 MMC drive.
Try an Android/Remix OS image and see if it is yielding the same results in terms of FS/partition corruption (try multiple cards). Remember to safely eject the cards when using windows (right click on drive > Eject in Explorer). For good measure wait a few minutes after the write to disk is completed.
If you are seeing the same issues on multiple cards even going through the paces of safe image writes then I would have to say the MMC card slot is faulty on either the PC or the Pine (not an uncommon thing). Try writing images from another system with a different MMC slot (this should help rule out your PCs if the same is still occurring leaving the Pine as the culprit)
Just a thought Wink
I wanted to ask if you have resized the RootFS after burning to disk?
If not then when you first login into your pine (linux image)
run
sudo -i
/usr/local/sbin/resize-rootfs.sh
That should resize the rootfs partition.
Let me know if you have any issues with corruption after doing that
Wink
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
RE: Debian Image In The Works - by umiddelb - 03-30-2016, 01:58 AM
RE: Debian Image In The Works - by tllim - 03-30-2016, 02:08 AM
RE: Debian Image In The Works - by longsleep - 03-30-2016, 11:50 AM
RE: Debian Image In The Works - by Bargepole - 04-02-2016, 05:57 AM
RE: Debian Image In The Works - by Ghost - 04-03-2016, 07:55 PM
RE: Debian Image In The Works - by Bargepole - 04-04-2016, 12:35 AM
RE: Debian Image In The Works - by tnecniv102 - 05-01-2016, 09:36 AM
RE: Debian Image In The Works - by tkaiser - 05-01-2016, 10:27 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 02:35 AM
RE: Debian Image In The Works - by merriam - 04-05-2016, 09:26 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:57 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:18 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 01:13 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 12:36 PM
RE: Debian Image In The Works - by longsleep - 04-09-2016, 05:35 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 05:51 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 02:22 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 03:03 PM
RE: Debian Image In The Works - by rahlquist - 04-07-2016, 05:30 AM
RE: Debian Image In The Works - by rahlquist - 04-08-2016, 06:13 AM
RE: Debian Jessie Images (3.10.65 BSP Kernel) - by lenny.raposo-pine64.pro - 04-08-2016, 07:20 AM
Success with this... - by cbbrowne - 04-13-2016, 10:16 AM
issue with 2 ethernet lines - by dkryder - 07-03-2016, 03:31 AM
  Debian installer on Pine A64+ but no hdmi mrwick 1 5,003 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 13,030 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 3,009 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,346 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 123,100 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,865 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,300 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,433 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,359 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 12,267 05-09-2018, 09:07 PM
Last Post: pfeerick
