(ARCHIVED) Debian Jessie Images (3.10.102 BSP Kernel) New Release
hello,
i recently bought a usb hub with a rj45[ethernet] port also. the port is recognized and set up as a 2nd ethernet at boot if two cables are connected or during a session if the cable is connect. throughput is fine.my issue is if the ethernet line 1 [the one on the board] is not connected while the 2nd line is operational the animation for searching for ip address for cable 1 is continuous. i'm thinking that either there should be no anjimation since no cable is physically attached or the search and the animation should time out after a cerain period of time, 30 - 90 secs, as desired.  are there any settings i should do? thanks.
RE: Debian Image In The Works - by umiddelb - 03-30-2016, 01:58 AM
RE: Debian Image In The Works - by tllim - 03-30-2016, 02:08 AM
RE: Debian Image In The Works - by longsleep - 03-30-2016, 11:50 AM
RE: Debian Image In The Works - by Bargepole - 04-02-2016, 05:57 AM
RE: Debian Image In The Works - by Ghost - 04-03-2016, 07:55 PM
RE: Debian Image In The Works - by Bargepole - 04-04-2016, 12:35 AM
RE: Debian Image In The Works - by tnecniv102 - 05-01-2016, 09:36 AM
RE: Debian Image In The Works - by tkaiser - 05-01-2016, 10:27 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 02:35 AM
RE: Debian Image In The Works - by merriam - 04-05-2016, 09:26 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:57 AM
RE: Debian Image In The Works - by Bargepole - 04-05-2016, 11:18 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 01:13 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 12:36 PM
RE: Debian Image In The Works - by longsleep - 04-09-2016, 05:35 PM
RE: Debian Image In The Works - by androsch - 04-09-2016, 05:51 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 02:22 PM
RE: Debian Image In The Works - by rahlquist - 04-06-2016, 03:03 PM
RE: Debian Image In The Works - by rahlquist - 04-07-2016, 05:30 AM
RE: Debian Image In The Works - by rahlquist - 04-08-2016, 06:13 AM
Success with this... - by cbbrowne - 04-13-2016, 10:16 AM
issue with 2 ethernet lines - by dkryder - 07-03-2016, 03:31 AM
  Debian installer on Pine A64+ but no hdmi mrwick 1 4,999 07-28-2020, 01:49 PM
Last Post: kuleszdl
  Debian Pine64 h264/5 Video under vlc ozcy 6 13,023 04-15-2020, 05:27 AM
Last Post: dmitrymyadzelets
  OMV/debian/systemd: how to start the network kittyland 0 3,006 12-10-2019, 05:29 PM
Last Post: kittyland
  Debian 10 (Buster) in deep freeze - includes support for Pine64+ amp 5 10,337 07-22-2019, 09:29 PM
Last Post: amp
  Pine64 Debian Stretch/mainline [4.14.7] CallMeFoxie 50 123,078 07-22-2019, 09:24 PM
Last Post: amp
  Installing Debian with the Debian Installer (Buster RC1) amp 1 4,861 06-28-2019, 12:35 PM
Last Post: Kaarme42
  Script to build pure Debian images for Pine64+ amp 1 4,297 05-01-2019, 09:09 PM
  Debian (Stretch) for Pine64-LTS wgray 2 6,429 04-04-2019, 09:54 PM
Last Post: wgray
  Is there just one fuctioning Debian Desktop image? KNERD 7 13,356 03-29-2019, 02:00 AM
Last Post: desai_amogh
  how to set kernel parameter 'fsck.mode=force' marcelser 6 12,263 05-09-2018, 09:07 PM
Last Post: pfeerick
