Wifi
(08-19-2017, 10:05 AM)Jakr Wrote: are you using a microsd card, or a emmc module?
What did you use to get android to your rock 64 .. SADIE?
what do you see on your screen?
does android boot up?
are the lights on the LAN connector, on the rock 64 lighting up .. the green, and the yellow ones .. are either, or both, or none lighting up?
are you using a .. known, good cable, are you sure the port on your router is working (many times, I have seen a port stop working, on a router).
I can not help you ,I haven't got android running on my rock 64 yet,  but I know .. these are some of the things you need to post, before someone can help you.
I was systems engineer for many, many years .. the best advice I can give you is .. the more information you can provide, the higher the chances are, someone can provide you with the help you need.
Jake
Hi Jake!
"are you using a microsd card, or a emmc module?" I'm using eMMC card 64GB
What did you use to get android to your rock 64 .. SADIE? AndroidTool_Release_v2.38
what do you see on your screen? the icon Wifi has question mark on it.
does android boot up? yes, it booting up completely
are the lights on the LAN connector, on the rock 64 lighting up .. the green, and the yellow ones .. are either, or both, or none lighting up? only the yellow light linking, no green light linking.
are you using a .. known, good cable, are you sure the port on your router is working (many times, I have seen a port stop working, on a router). Yes I have change some of cables which are using good with my computer and router.
I was systems engineer for many, many years .. the best advice I can give you is .. the more information you can provide, the higher the chances are, someone can provide you with the help you need.  I have flash 3 times completely, but the result are the same, not connect to internet by ethernet. I have flash two version Android V0.1.8 r48 and V0.2.7 r59 the same result.
Jake
Wifi - by dsmart978 - 08-15-2017, 01:30 PM
RE: Wifi - by Jakr - 08-19-2017, 09:16 AM
RE: Wifi - by dhruan - 08-19-2017, 09:45 AM
RE: Wifi - by Jakr - 08-19-2017, 10:05 AM
RE: Wifi - by dhruan - 08-19-2017, 08:23 PM
RE: Wifi - by nilesh7 - 08-19-2017, 10:40 AM
RE: Wifi - by nilesh7 - 08-20-2017, 04:27 AM
RE: Wifi - by Jakr - 08-20-2017, 10:20 AM
RE: Wifi - by dhruan - 08-21-2017, 04:24 AM
RE: Wifi - by Jakr - 08-21-2017, 08:39 AM
  USB WiFi dongle tplink TL-WN821N AlexS 1 3,350 09-05-2020, 02:42 PM
Last Post: BowerR64
  ROCK64 USB WIFI 802.11B/G/N (RTL8188EU) admiral_andersen 0 2,179 09-07-2019, 04:21 AM
Last Post: admiral_andersen
  Supported 5GHZ Wifi Adapters? bryguy 1 3,421 12-03-2017, 12:55 PM
  Does “0.2.14: jenkins-android-7.1-rock-64-69” support wifi? fbms 5 6,946 10-18-2017, 07:50 AM
Last Post: Guy the IT Guy
  Wifi dsmart978 0 1,693 08-15-2017, 12:55 PM
Last Post: dsmart978
