Android Images (ROCK64)
#28
(01-10-2018, 02:45 PM)richzhai Wrote: Android 7.1.2 Stock Image [microSD Boot] [Rooted] [20171204] easily hang on ROCK64 4GB.
ayufan mentioned his Android regular (not ATV) build doesn't work on ROCK64 4GB board.
if anyone know if there is a stable Android 7.x eMMC build for ROCK54 4GB board, please share. Many thanks!
Hey Richzhai. I found that etcher is sketchy, winimage was fine, but really what worked for me was rufus. I have a standard 16gb sdmicro, with a usb converter. Formatted, chose image; rufus booted both android which ayufan claims didn't work DID! wireless and all on both worked! I also used it to install the xenial which also booted! Both of which failed to boot using etcher and winimage! I booted into Linux to unzip the (rock64****.**.**136.)img.xz make sure you use a ntfs disk to extract onto. In androids case that's not necessary, small enough! It took a couple of boots, but worked smoothly, easily and don't understand why everyone suggested etcher? I also burned LAKKA, but etcher was utterly useless IMHO. I've been using PI's for awhile and expected the ROCK64 to be difficult, but it wasn't; just with etcher! I see all kinds of problems with people who can't boot! For that matter, I suppose other usb boot tools Like YUMI, also should work great! Anyway, I switched between Linux and windows to extract then burn on the microsd card.
Hope this helps you get going. Wireless worked on both android and xenial, everything was fine with rufus! I had to restart android after first install because I forgot to insert the USB wireless dongle, but after the reboot, worked nicely, recognized wireless and all! ayufan claims it doesn't work? I don't know why!
I have the rock64 with 4gb, and am going to order a 64gb mmc card now! Cards just don't read well...
Cheers. and good luck...
Digigil...
Android Images (ROCK64) - by pineadmin - 08-08-2017, 01:21 AM
RE: Android Images (ROCK64) - by pineadmin - 09-12-2017, 11:50 PM
RE: Android Images (ROCK64) - by pineadmin - 10-02-2017, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 10-23-2017, 03:26 AM
RE: Android Images (ROCK64) - by andfun - 10-26-2017, 01:47 AM
RE: Android Images (ROCK64) - by pineadmin - 10-27-2017, 02:50 AM
RE: Android Images (ROCK64) - by Luke - 10-27-2017, 07:08 AM
RE: Android Images (ROCK64) - by dkryder - 10-29-2017, 01:53 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 03:25 PM
RE: Android Images (ROCK64) - by dudemo - 10-29-2017, 03:52 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 04:59 PM
RE: Android Images (ROCK64) - by medc69 - 10-30-2017, 02:40 PM
RE: Android Images (ROCK64) - by dkryder - 10-30-2017, 08:57 PM
RE: Android Images (ROCK64) - by pineadmin - 01-04-2018, 09:52 AM
RE: Android Images (ROCK64) - by wanb1i - 04-08-2018, 09:01 AM
RE: Android Images (ROCK64) - by Luke - 01-04-2018, 10:33 AM
RE: Android Images (ROCK64) - by pineadmin - 01-07-2018, 10:16 PM
RE: Android Images (ROCK64) - by dudemo - 01-08-2018, 06:06 AM
RE: Android Images (ROCK64) - by dudemo - 01-04-2018, 07:41 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 12:45 PM
RE: Android Images (ROCK64) - by toby - 01-05-2018, 02:51 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 07:23 PM
RE: Android Images (ROCK64) - by richzhai - 01-10-2018, 02:45 PM
RE: Android Images (ROCK64) - by pgmy64 - 01-10-2018, 10:55 PM
RE: Android Images (ROCK64) - by richzhai - 01-11-2018, 10:51 AM
RE: Android Images (ROCK64) - by pgmy64 - 01-12-2018, 12:31 AM
RE: Android Images (ROCK64) - by Digigil - 02-12-2018, 09:05 AM
RE: Android Images (ROCK64) - by isndw - 02-09-2018, 09:14 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:05 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:50 AM
RE: Android Images (ROCK64) - by elik745i - 02-25-2018, 03:04 AM
RE: Android Images (ROCK64) - by el_gringo - 02-25-2018, 09:53 AM
RE: Android Images (ROCK64) - by elik745i - 02-26-2018, 01:11 PM
RE: Android Images (ROCK64) - by rarekumiko - 02-26-2018, 11:41 PM
RE: Android Images (ROCK64) - by piraeus - 03-05-2018, 02:58 AM
RE: Android Images (ROCK64) - by Nelly - 03-18-2018, 04:02 AM
RE: Android Images (ROCK64) - by Poincare - 04-05-2018, 08:25 PM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 09:56 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 10:42 AM
RE: Android Images (ROCK64) - by dougunder - 05-05-2018, 04:43 PM
RE: Android Images (ROCK64) - by Poincare - 05-06-2018, 06:31 AM
RE: Android Images (ROCK64) - by Luke - 05-06-2018, 06:52 AM
RE: Android Images (ROCK64) - by dougunder - 05-06-2018, 08:58 AM
RE: Android Images (ROCK64) - by mlade77 - 05-08-2018, 04:03 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-22-2018, 02:31 PM
RE: Android Images (ROCK64) - by jzhang18 - 06-01-2018, 11:37 AM
RE: Android Images (ROCK64) - by pineadmin - 06-25-2018, 01:34 AM
RE: Android Images (ROCK64) - by geno - 06-27-2018, 05:52 AM
RE: Android Images (ROCK64) - by Luke - 06-27-2018, 08:25 AM
RE: Android Images (ROCK64) - by Poincare - 07-11-2018, 07:35 PM
RE: Android Images (ROCK64) - by ameridroid - 08-13-2018, 09:15 PM
RE: Android Images (ROCK64) - by gbjensen - 09-07-2018, 09:37 AM
RE: Android Images (ROCK64) - by fender90 - 09-07-2018, 01:07 PM
RE: Android Images (ROCK64) - by mranderson - 01-18-2019, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 06-20-2019, 12:13 AM
RE: Android Images (ROCK64) - by AlexS - 06-27-2019, 09:25 AM
RE: Android Images (ROCK64) - by lumix14 - 08-25-2019, 06:59 AM
RE: Android Images (ROCK64) - by AlexS - 09-16-2019, 09:01 AM
RE: Android Images (ROCK64) - by fender90 - 06-20-2019, 10:45 PM
RE: Android Images (ROCK64) - by tllim - 06-23-2019, 12:48 AM
RE: Android Images (ROCK64) - by totalgaara - 06-24-2019, 11:01 PM
RE: Android Images (ROCK64) - by R_V - 09-12-2019, 04:58 PM
RE: Android Images (ROCK64) - by elik745i - 09-20-2019, 09:54 AM
RE: Android Images (ROCK64) - by Pepe - 04-11-2020, 04:30 PM
RE: Android Images (ROCK64) - by tllim - 04-14-2020, 11:02 PM
RE: Android Images (ROCK64) - by Pepe - 04-19-2020, 06:30 AM
RE: Android Images (ROCK64) - by tllim - 04-20-2020, 12:34 AM
RE: Android Images (ROCK64) - by ricklar - 05-22-2020, 03:44 AM
RE: Android Images (ROCK64) - by Chaitanyalohith - 08-03-2020, 12:41 AM
RE: Android Images (ROCK64) - by seaurchin - 08-03-2020, 02:20 PM
RE: Android Images (ROCK64) - by tophneal - 08-04-2020, 08:08 AM
RE: Android Images (ROCK64) - by BowerR64 - 09-02-2020, 09:52 PM
RE: Android Images (ROCK64) - by zet_lab - 05-04-2021, 01:58 AM
RE: Android Images (ROCK64) - by Blackheat45 - 05-09-2024, 02:40 PM
RE: Android Images (ROCK64) - by manf001 - 05-11-2024, 03:57 PM
RE: Android Images (ROCK64) - by tllim - 05-13-2024, 04:13 PM
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 6,426 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,407 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,123 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,633 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,076 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,555 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,109 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,619 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,793 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,930 09-09-2020, 08:44 AM
Last Post: BowerR64
