Android Images (ROCK64)
well, Luke, i find the supplied launcher causes a lot more clicks than necessary. one click highlights, then 2nd click loads? why not just load on the 1st click? anyway, the launcher was the first thing i changed on the build. i wanted to say good job on the root this build. was able to update via supersu and the process did not bork the build. root checker shows that root install was proper and every app that needed root got it no problems. i will say that using terminal to give /system write privledges worked as needed. the only issue i have had is some of my paid apps do not register as paid on this build. i did update play services. . i just don't get why half work and half don't. anyway, good job on root this build, it's the best one since june 2016.
Android Images (ROCK64) - by pineadmin - 08-08-2017, 01:21 AM
RE: Android Images (ROCK64) - by pineadmin - 09-12-2017, 11:50 PM
RE: Android Images (ROCK64) - by pineadmin - 10-02-2017, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 10-23-2017, 03:26 AM
RE: Android Images (ROCK64) - by andfun - 10-26-2017, 01:47 AM
RE: Android Images (ROCK64) - by pineadmin - 10-27-2017, 02:50 AM
RE: Android Images (ROCK64) - by Luke - 10-27-2017, 07:08 AM
RE: Android Images (ROCK64) - by dkryder - 10-29-2017, 01:53 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 03:25 PM
RE: Android Images (ROCK64) - by dudemo - 10-29-2017, 03:52 PM
RE: Android Images (ROCK64) - by Luke - 10-29-2017, 04:59 PM
RE: Android Images (ROCK64) - by medc69 - 10-30-2017, 02:40 PM
RE: Android Images (ROCK64) - by dkryder - 10-30-2017, 08:57 PM
RE: Android Images (ROCK64) - by pineadmin - 01-04-2018, 09:52 AM
RE: Android Images (ROCK64) - by wanb1i - 04-08-2018, 09:01 AM
RE: Android Images (ROCK64) - by Luke - 01-04-2018, 10:33 AM
RE: Android Images (ROCK64) - by pineadmin - 01-07-2018, 10:16 PM
RE: Android Images (ROCK64) - by dudemo - 01-08-2018, 06:06 AM
RE: Android Images (ROCK64) - by dudemo - 01-04-2018, 07:41 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 12:45 PM
RE: Android Images (ROCK64) - by toby - 01-05-2018, 02:51 PM
RE: Android Images (ROCK64) - by quantik - 01-05-2018, 07:23 PM
RE: Android Images (ROCK64) - by richzhai - 01-10-2018, 02:45 PM
RE: Android Images (ROCK64) - by pgmy64 - 01-10-2018, 10:55 PM
RE: Android Images (ROCK64) - by richzhai - 01-11-2018, 10:51 AM
RE: Android Images (ROCK64) - by pgmy64 - 01-12-2018, 12:31 AM
RE: Android Images (ROCK64) - by Digigil - 02-12-2018, 09:05 AM
RE: Android Images (ROCK64) - by isndw - 02-09-2018, 09:14 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:05 AM
RE: Android Images (ROCK64) - by elik745i - 02-24-2018, 01:50 AM
RE: Android Images (ROCK64) - by elik745i - 02-25-2018, 03:04 AM
RE: Android Images (ROCK64) - by el_gringo - 02-25-2018, 09:53 AM
RE: Android Images (ROCK64) - by elik745i - 02-26-2018, 01:11 PM
RE: Android Images (ROCK64) - by rarekumiko - 02-26-2018, 11:41 PM
RE: Android Images (ROCK64) - by piraeus - 03-05-2018, 02:58 AM
RE: Android Images (ROCK64) - by Nelly - 03-18-2018, 04:02 AM
RE: Android Images (ROCK64) - by Poincare - 04-05-2018, 08:25 PM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 09:56 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-01-2018, 10:42 AM
RE: Android Images (ROCK64) - by dougunder - 05-05-2018, 04:43 PM
RE: Android Images (ROCK64) - by Poincare - 05-06-2018, 06:31 AM
RE: Android Images (ROCK64) - by Luke - 05-06-2018, 06:52 AM
RE: Android Images (ROCK64) - by dougunder - 05-06-2018, 08:58 AM
RE: Android Images (ROCK64) - by mlade77 - 05-08-2018, 04:03 AM
RE: Android Images (ROCK64) - by jzhang18 - 05-22-2018, 02:31 PM
RE: Android Images (ROCK64) - by jzhang18 - 06-01-2018, 11:37 AM
RE: Android Images (ROCK64) - by pineadmin - 06-25-2018, 01:34 AM
RE: Android Images (ROCK64) - by geno - 06-27-2018, 05:52 AM
RE: Android Images (ROCK64) - by Luke - 06-27-2018, 08:25 AM
RE: Android Images (ROCK64) - by Poincare - 07-11-2018, 07:35 PM
RE: Android Images (ROCK64) - by ameridroid - 08-13-2018, 09:15 PM
RE: Android Images (ROCK64) - by gbjensen - 09-07-2018, 09:37 AM
RE: Android Images (ROCK64) - by fender90 - 09-07-2018, 01:07 PM
RE: Android Images (ROCK64) - by mranderson - 01-18-2019, 03:23 AM
RE: Android Images (ROCK64) - by pineadmin - 06-20-2019, 12:13 AM
RE: Android Images (ROCK64) - by AlexS - 06-27-2019, 09:25 AM
RE: Android Images (ROCK64) - by lumix14 - 08-25-2019, 06:59 AM
RE: Android Images (ROCK64) - by AlexS - 09-16-2019, 09:01 AM
RE: Android Images (ROCK64) - by fender90 - 06-20-2019, 10:45 PM
RE: Android Images (ROCK64) - by tllim - 06-23-2019, 12:48 AM
RE: Android Images (ROCK64) - by totalgaara - 06-24-2019, 11:01 PM
RE: Android Images (ROCK64) - by R_V - 09-12-2019, 04:58 PM
RE: Android Images (ROCK64) - by elik745i - 09-20-2019, 09:54 AM
RE: Android Images (ROCK64) - by Pepe - 04-11-2020, 04:30 PM
RE: Android Images (ROCK64) - by tllim - 04-14-2020, 11:02 PM
RE: Android Images (ROCK64) - by Pepe - 04-19-2020, 06:30 AM
RE: Android Images (ROCK64) - by tllim - 04-20-2020, 12:34 AM
RE: Android Images (ROCK64) - by ricklar - 05-22-2020, 03:44 AM
RE: Android Images (ROCK64) - by Chaitanyalohith - 08-03-2020, 12:41 AM
RE: Android Images (ROCK64) - by seaurchin - 08-03-2020, 02:20 PM
RE: Android Images (ROCK64) - by tophneal - 08-04-2020, 08:08 AM
RE: Android Images (ROCK64) - by BowerR64 - 09-02-2020, 09:52 PM
RE: Android Images (ROCK64) - by zet_lab - 05-04-2021, 01:58 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,341 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,063 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,596 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,043 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,526 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,069 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,597 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,758 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,875 09-09-2020, 08:44 AM
Last Post: BowerR64
  Boot Android from USB? Max_H 3 6,588 09-09-2020, 08:26 AM
Last Post: BowerR64
