micro SD slot (updates)
(07-14-2017, 10:23 PM)tllim Wrote: On ROCK64 board?
That's what I was wondering too... I thought you said production rock64s would be the push/pull type. Me thinks this user might have posted in the wrong forum... hopefully he'll post back to let us know. Assuming this is the pine64 sprung card mechanism the OP is talking about... I also had a bit of trouble with one board not retaining the cards... the metal flap that was supposed to lock the card into place had popped up a bit, so I gently pressed it in when there was no card in the slot, and it has been fine ever since. Hopefully that will fix the OPs issue also.
micro SD slot (updates) - by shanewiley - 07-14-2017, 09:13 PM
RE: micro SD slot (fault) - by MarkHaysHarris777 - 07-14-2017, 09:22 PM
RE: micro SD slot (fault) - by tllim - 07-14-2017, 10:23 PM
RE: micro SD slot (fault) - by pfeerick - 07-15-2017, 03:50 AM
RE: micro SD slot (updates) - by dkryder - 07-15-2017, 05:32 AM
RE: micro SD slot (updates) - by dkryder - 07-16-2017, 01:42 AM
RE: micro SD slot (updates) - by pfeerick - 07-15-2017, 06:23 PM
RE: micro SD slot (updates) - by dkryder - 07-16-2017, 07:53 PM
RE: micro SD slot (updates) - by soichiro - 11-29-2017, 08:20 PM
RE: micro SD slot (updates) - by tllim - 12-03-2017, 11:22 AM
  Replacement PCIe slot whotook 1 1,984 12-08-2021, 05:39 AM
Last Post: CounterPillow
  Ejection mechanism of microSD slot DOA kuleszdl 2 4,127 09-05-2020, 03:24 PM
Last Post: kuleszdl
  rockpro64 startx hangs system if ssd drive installed in PCIe slot shoupydad 0 1,660 01-24-2019, 07:11 PM
Last Post: shoupydad
  Rock64 micro-sd controller defective? soichiro 18 21,175 12-01-2018, 06:11 PM
Last Post: z4v4l
