rockpro64 startx hangs system if ssd drive installed in PCIe slot
Hi All,
I am new to this forum.  I am using 5 rockpro64's as a "cheap" cluster computer for parallel numerical general relativity simulations.  Only been working on it about a month.  I just installed a Samsung 500 GB ssd (960 Evo) on my head node.  I have it partitioned and formatted.  It works well.   However, now I can't do a startx command from the command line.  The system gets to the point of showing the graphical desktop with the cursor in the middle, but then hangs.  No keyboard or mouse response.  Lights on the keyboard and mouse are on.
If I power off/on then ssh into the system from another node, I can see the that ssd is automounted and I have access to it.  I can't think of a way to debug this.  Usually I like solving problems, but I don't know where to begin with this one.
Thanks for any help any of you can give. Smile
  7" LCD on RockPro64 spammycheese 1 921 03-10-2023, 04:05 PM
Last Post: peteressive
  Replacement PCIe slot whotook 1 1,916 12-08-2021, 05:39 AM
Last Post: CounterPillow
  Ejection mechanism of microSD slot DOA kuleszdl 2 4,055 09-05-2020, 03:24 PM
Last Post: kuleszdl
  Which Voltage and Amper to supply both Rock64 + External drive enclosure ? prog-amateur 0 2,510 08-21-2020, 09:16 PM
Last Post: prog-amateur
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 15,998 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64 stereo audio dac add-on board with RockPro64 Tim13 1 3,535 07-08-2019, 07:15 PM
  Fitting Rockpro64 inside Pinebook case made2hack 2 3,726 02-20-2019, 01:27 AM
Last Post: made2hack
  PCIe extender cable for M2 grimace 1 2,475 02-15-2019, 11:15 AM
Last Post: fonix232
  RockPro64 and JustBoom DAC and AMP goranobradovic 0 1,769 12-14-2018, 11:34 AM
Last Post: goranobradovic
  Powering off 3.5 I drive with r64 Jxck 1 2,589 07-10-2018, 04:32 PM
Last Post: evilbunny
