Anyway to run Teamviewer for ARM/Pinebook?
(06-29-2017, 01:00 PM)Ekkaia Wrote: Tried host version (...armhf.deb) (install requires a lot of libqt5* libs) so "sudo gdebi ...deb" and done almost ok and fails in some "qtdeclarative5*" libs.
Anyway Host version is "not" the solution: the goal is to access to your PCs from pinebook (for support for example).
Also tried to install the Teamviewer Chrome application (in Chromium, could be a solution) but when it's going to launch says "Native Client is needed". Also tried to install this "Native Client" (no clue about its existence) but also no luck Sad
Maybe got working this "Native Client" Chrome thing is the simplest solution.
Did you get a resolution to this?  I use Team Viewer (and AnyDesk) for remote support of family member's PCs, as well.  Hate to revert back to my Windoz box for that.  :-)
Dennis Hoshield
PBPro/ANSI/Manjaro
RE: Anyway to run Teamviewer for ARM/Pinebook? - by dhosh - 01-16-2020, 06:04 PM
  DietPi OS for Pinebook MichaIng 3 5,497 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 61,501 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 944 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 733 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,796 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,265 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,923 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,297 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,842 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,821 12-25-2020, 04:40 PM
Last Post: ford442
