Error formatting MicroSD
#19
(04-10-2016, 05:47 AM)rikardo1979 Wrote:
(04-08-2016, 07:04 AM)rahlquist Wrote:
(04-08-2016, 04:14 AM)yusijs Wrote: I don't understand why we have to use the horrible software (PhoenixCard). I've tried with multiple SD cards now (2 of which I've used to run my RPI2s on), and it just says:
The Remix and Android images need to resize the /data partiton when the image is transferred to the sd card. Thats part of what PhoenixCard does. After it lays out the image on the SD it then resizes the /data partition to the available space.
this can be done the much better way. something like we have on XBian. After you flash your image to the card, you put it to RPi and the whole resize happened in first boot.
I gave up on this board. Seems I have make a bad choice buying this.
Nothing is ready, nothing is as suppose to be....bad, very bad choice. I simply wasted my money.
Luckily I still have few of my RPi's so I keep using those and buy more.
This board is going to die pretty soon and be forgotten..same as Bananapi or others
You dont think thats a bit much. Comming to that conclution even befor te Pine community has had a chance to build it into what its capable of? Not everyone has recieved their boards yet, and when we all do I bet there will be alot of bugfixes comming our way. You need to remember that this is a product still in the startditch.
I do understand your frustration, but I dont understand why you backed a campaign like this if you are allergic to startup problems.
Yes the KS campaign led us to believe this was a fully functionalling SBC but like anything with a small community, things take time.
Still looking forward to recieving my Pine and hoping for some really good, stable builds to get around (Android/RemixOS for the 2Gb board)
Error formatting MicroSD - by Terra854 - 03-17-2016, 08:09 AM
Error formatting MicroSD - by skybadiver - 03-18-2016, 07:19 PM
RE: Error formatting MicroSD - by KryPtAlIvIaN - 03-18-2016, 07:51 PM
Error formatting MicroSD - by skybadiver - 03-19-2016, 08:47 PM
RE: Error formatting MicroSD - by Terra854 - 03-20-2016, 03:02 AM
RE: Error formatting MicroSD - by Andrew2 - 03-20-2016, 03:14 AM
RE: Error formatting MicroSD - by mhump711 - 04-03-2016, 12:07 PM
RE: Error formatting MicroSD - by tllim - 04-03-2016, 02:23 PM
RE: Error formatting MicroSD - by mhump711 - 04-03-2016, 03:24 PM
RE: Error formatting MicroSD - by mhump711 - 04-03-2016, 08:39 PM
RE: Error formatting MicroSD - by Rhymoore - 04-06-2016, 05:34 AM
RE: Error formatting MicroSD - by AnaNova - 03-07-2017, 01:31 AM
RE: Error formatting MicroSD - by rikardo1979 - 04-06-2016, 11:08 PM
RE: Error formatting MicroSD - by yusijs - 04-08-2016, 04:14 AM
RE: Error formatting MicroSD - by rahlquist - 04-08-2016, 07:04 AM
RE: Error formatting MicroSD - by rikardo1979 - 04-10-2016, 05:47 AM
RE: Error formatting MicroSD - by Tarjei85 - 04-10-2016, 06:21 AM
RE: Error formatting MicroSD - by rikardo1979 - 04-10-2016, 06:34 AM
RE: Error formatting MicroSD - by yusijs - 04-08-2016, 05:15 AM
RE: Error formatting MicroSD - by AwkwardEquation - 04-08-2016, 06:36 AM
RE: Error formatting MicroSD - by yusijs - 04-08-2016, 07:01 AM
RE: Error formatting MicroSD - by patrickhwood - 04-14-2016, 10:04 PM
  SD card too small Error loungehound 7 12,793 01-21-2017, 05:37 PM
Last Post: Bluphire
  Netflix (v4.9.5) Error 1018 on Playback evanthor 3 16,100 12-19-2016, 09:24 AM
Last Post: Bluphire
  MicroSD Size mismatch with Image Hbtr 23 28,873 08-31-2016, 09:00 AM
Last Post: montero65
  Change MicroSD card AA666 2 4,534 05-26-2016, 01:20 PM
Last Post: AA666
