Can not get board to boot up reliably
Hi pkfpeters,
" Do you mean by "official" wifi 802.11bgn module, the add on wifi/bt board you can order in the online Pine shop?"
> Yes
"I also tested with this board and it should work fine. Have you tried ifconfig -a
or iwconfig ? You should see a wlan0, wlan1 or something similar"
> I can see booth wlan0 and wlan1
"If your access point is providing IP addresses (DHCP based) use the following command to aquire a valid IP address  dhclient -i wlan0   <<-- replace wlan0 with your device name."
> Access point do not provide IP address
"You boot log indicates abnormal boot times indeed. I am currently up and running from power on to login prompt in 28seconds."
> I cut  and  paste Boot log  to answer, but it was third (if I remember correct) booting loop round.
Today's experiments
I make fresh start and flash Samsung 32GB EVO (Etcher Pine version)
pine64-image-debianmate-310102bsp-2.img
Booting was OK, but no network (Eth0 or Wlan)
debian@pine64:~$ sudo ifconfig -a
dummy0    Link encap:Ethernet  HWaddr de:56:8d:bf:dc:41
         BROADCAST NOARP  MTU:1500  Metric:1
         RX packets:0 errors:0 dropped:0 overruns:0 frame:0
         TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:0
         RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
eth0      Link encap:Ethernet  HWaddr 36:c9:e3:f1:b8:05
         inet6 addr: fe80::34c9:e3ff:fef1:b805/64 Scope:Link
         UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
         TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:1000
         RX bytes:0 (0.0 B)  TX bytes:2339 (2.2 KiB)
         Interrupt:114
lo        Link encap:Local Loopback
         inet addr:127.0.0.1  Mask:255.0.0.0
         inet6 addr: ::1/128 Scope:Host
         UP LOOPBACK RUNNING  MTU:65536  Metric:1
sit0      Link encap:IPv6-in-IPv4
         NOARP  MTU:1480  Metric:1
wlan0     Link encap:Ethernet  HWaddr 34:c3:d2:b3:65:86
         UP BROADCAST MULTICAST  MTU:1500  Metric:1
wlan1     Link encap:Ethernet  HWaddr 36:c3:d2:b3:65:86
Several times reboot but no IPaddress (with or without wifi card)
So I can not install yours patc, because first instruction is
sudo apt-get update
sudo apt-get upgrade
and after that yours patch.
chiken -egg problem :-)
Next time when trying Debian I install first yours patch and after that update and upgrade.
But before that playing with Ubuntu.
Result is:
Ubuntu Base Image build 20161218-1 7.7GB Pine64 V2.0.0-beta2 (Etcher Pine version)
Boot problem two times (stay in booting loop. Only solutions is power off -> on).
Third boot trying -> OK
ubuntu@pine64:~$ ifconfig -a
dummy0    Link encap:Ethernet  HWaddr 8a:d5:e7:d9:ed:9e
eth0      Link encap:Ethernet  HWaddr ce:8c:40:1a:43:c1
         inet addr:192.168.0.28  Bcast:192.168.0.255  Mask:255.255.255.0
         inet6 addr: fe80::cc8c:40ff:fe1a:43c1/64 Scope:Link
         RX packets:16 errors:0 dropped:0 overruns:0 frame:0
         TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:2326 (2.3 KB)  TX bytes:1684 (1.6 KB)
         Interrupt:114
         RX packets:80 errors:0 dropped:0 overruns:0 frame:0
         TX packets:80 errors:0 dropped:0 overruns:0 carrier:0
         RX bytes:5920 (5.9 KB)  TX bytes:5920 (5.9 KB)
So no Wlan but Eth0 working and booting is reliable after patch
And again I tried Android 7.1 version because SD card was ready and it is not bad idea check out wifi module health.
This time HDMI is in use. Debian and Ubuntu tryed Putty serial connection.
Booting, eth0 and wlan was OK
Android working OK. Reliable booting, wlan and lan.
Is this booting problem relatetd to Pine64 PCB version?
My version is A64-DB-2G-Rev B 2016-03-21
BR: Kaarme42
Can not get board to boot up reliably - by Leo - 04-24-2017, 01:41 AM
RE: Can not get board to boot up reliably - by Kaarme42 - 06-17-2017, 06:04 AM
  Debian Base (3.10.102 BSP 2) won't boot without monitor Scion 7 12,387 09-16-2016, 03:58 PM
Last Post: Scion
  Possible to add a boot logo for boot? Darkshadow2913 4 5,798 09-09-2016, 06:02 AM
Last Post: Darkshadow2913
  Very long boot time with Debian image Xabaras76 5 7,490 07-14-2016, 03:49 PM
Last Post: Xabaras76
  Debian base(102) n xfce(101) does not boot HenryD 2 3,151 07-09-2016, 04:50 PM
Last Post: HenryD
