Pine64 cannot boot
(03-23-2017, 11:14 PM)pfeerick Wrote:
(03-23-2017, 10:32 PM)jamiechang917 Wrote: Ubuntu 16.04 with Xfce DE and armbian,it can boot but not successful every time.All I get is a steady red LED and its Ethernet doesn't work.
If your board is powering on (red light), but the ethernet lights aren't showing signs of life after 20-30 seconds, it's probably worth looking at the power supply setup. See if you can use a good quality short USB lead. Try a different 5v power supply with at least a 2A rating (more is fine). If you feel up to it, try powering the pine64 via the euler connector (look at the pinout link in my signature) so we can eliminate the microUSB cable and connector as being an issue.
Thanks,I'll give it a try.
Pine64 cannot boot - by jamiechang917 - 03-23-2017, 08:30 AM
RE: Pine64 cannot boot - by xalius - 03-23-2017, 08:57 AM
RE: Pine64 cannot boot - by jamiechang917 - 03-23-2017, 10:32 PM
RE: Pine64 cannot boot - by pfeerick - 03-23-2017, 11:14 PM
RE: Pine64 cannot boot - by jamiechang917 - 03-24-2017, 03:30 AM
RE: Pine64 cannot boot - by Dagremote - 04-16-2017, 09:50 AM
RE: Pine64 cannot boot - by pfeerick - 04-16-2017, 10:21 PM
  Programming languages support under PINE64 baryluk 6 12,373 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 5,934 10-19-2019, 05:13 AM
Last Post: roel
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,252 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Volumio for PINE64 Released mikelangeloz 11 24,573 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,055 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 6,016 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 35,388 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,125 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,666 06-21-2018, 05:45 PM
Last Post: evilbunny
  Secure boot & OTP efuse program devangpanchal90 0 2,616 05-25-2018, 01:59 AM
Last Post: devangpanchal90
