Strange. The red light is ok - it just means power. Take the SD out of the pine and pop it into a Linux box. You will find what you are looking for under /boot in the uEnv.txt file. If you managed to ssh into the pine you can:
Whats the native resolution of your monitor?
You can also try using one of the armbian imgs.
If you cant get it working, join the chat (in my sig) and pose the question --- someone will eventually get back to you and help you out.
[edit] glad to hear you got it working. HDMI cable was the issue ? strange. Make sure to update the kernel, take a look in: /usr/local/sbin
nano /boot/uEnv.txt
