just trying to play a youtube video
Sad
hey
so a reminder:
I successfully managed to boot and start up my 512MB DDR pine64 with Debian, the internet connection via wifi works fine.
obviously as a pilot test I wanted to watch a youtube video, but it takes forever even start playing it - iceweasel soon gets stucked, pops out a script error and I must close the browser.
I know that the 512MB is the most basic model, but come on - it can't even run a youtube video?
is there something i can actually do? higher voltage on the power supply (now it's a 2.1A 5V)? using another app or browser (though even Kodi runs slowly)?
really hope theres another solution rather than spending extra money on the pine64+ or, god forbid, rasp pi...
thanks in advance...
Playing a YouTube video is not a correct test and ist totally unrelated to the amount of RAM. Also if you have the 512mb model it is not a good idea to install a desktop environment as most required more RAM than that.
(05-20-2016, 04:16 PM)longsleep Wrote: Playing a YouTube video is not a correct test and ist totally unrelated to the amount of RAM. Also if you have the 512mb model it is not a good idea to install a desktop environment as most required more RAM than that.
Then how can i play a youtube video normally with these settings?  i mainly bought the pine to use it as a media center for my tv, youtube is basic use rather than a test.
 there's no other desktop envirnoment suitable for the 512mb model which uses less RAM? anything being developed right now?
and finally, if i'd like to extend my RAM, is there any way i could do that with an external RAM module?
Really thank you for the answers Blush
Unfortunately RAM can't be upgraded, as it is soldered directly onto the board.
Also sadly, the focus for most development does seem to be for the 1GB and 2GB RAM Pine64 models, so the 512MB model is getting left behind in this respect...
(05-21-2016, 01:30 AM)galbez Wrote: Then how can i play a youtube video normally with these settings?  i mainly bought the pine to use it as a media center for my tv, youtube is basic use rather than a test.
Well then you clearly bought the wrong device. You can try android which has hardware accelerated video decode which also might work with Youtube (but i have no clue about Android and it does not seem to be supported on the 512MB model).
(05-21-2016, 01:30 AM)galbez Wrote:  there's no other desktop envirnoment suitable for the 512mb model which uses less RAM? anything being developed right now?
Sure there are plenty desktop environments for Linux with work with 512MB model. Probably the easiest to use would be LXDE. Still this has nothing todo with hardware accelerated video decoding (especially in the browser) which might as well never happen for the Pine64.
no any other lite version of android suitable for 512MB/lite specifications was ever developed? like older versions (up to KitKat)?
has anyone tried android on a 512MB model, or it's not even possible to install it?
i'll try the LXDE though, thanks. really trying to max out this model before ordering the 1/2GB  Wink
I have the 2gb model and I cant play you tube video... Huh
  Video conferencing aproject oxoocoffee 1 3,057 03-31-2020, 09:24 PM
Last Post: Dendrocalamus64
Video May dietpi save Pine64 ; watch youtube via chromium hatahata 12 18,551 03-09-2017, 07:41 PM
Last Post: pfeerick
  red led + cat5 lights but noshow on DHCP list, no video mckenna.tim 1 3,824 01-24-2017, 12:03 PM
Last Post: Luke
  SSH works, but no video SvdSinner 8 10,832 12-08-2016, 12:59 PM
Last Post: MarkHaysHarris777
  My personal discovery of no video upon first booting my Pine A64 AZ_Ron 3 5,482 08-17-2016, 02:10 PM
Last Post: efalsken
  HDMI Video Resolution patmolloy 11 21,540 07-27-2016, 10:37 PM
Last Post: jwouellette
  Video Tutorial To Create Bootable SD-Card pineadmin 12 27,598 07-17-2016, 03:48 AM
Last Post: Ghost
  DOA Board? "UNSUPPORTED VIDEO" phloog 21 30,383 07-02-2016, 02:37 AM
  Ubuntu Video Performance mliebski 1 3,169 07-01-2016, 03:46 PM
  Video Rickyroller5 3 5,141 06-17-2016, 10:45 PM
Last Post: Ghost
