Is the Wifi module working?
(11-18-2016, 07:55 PM)clawinus Wrote: Thanks for replying to my inquiry.
I am using Debian Jessie Base & Mate Images
downloaded from the Pine64 site.
How I installed the wifi module and the contents of the interfaces file
are shown in the attached photos.
I hope I have put in the wifi module the right way.
I took the photo of the interfaces file when the Wifi adapter was not plugged into the USB slot.
A wlan 0 and wlan1 are recognized. How do I disable wlan1?
Simply remove the '#' from in front of iface wlan1 inet manual. This makes it so the network manager no longer manages wlan1.
From your picture, that looks to be the right way around.
Have you been able to configure your wifi connection yet, or are you still stuck? If you are, have a look at this post, as those steps should get you working. If not, just about any generic linux command line wifi instructions (like this one) should get you 90% of the way ;-)
Is the Wifi module working? - by clawinus - 11-14-2016, 09:37 AM
RE: Is the Wifi module working? - by pfeerick - 11-14-2016, 07:21 PM
RE: Is the Wifi module working? - by clawinus - 11-18-2016, 07:55 PM
RE: Is the Wifi module working? - by pfeerick - 11-19-2016, 01:58 AM
RE: Is the Wifi module working? - by clawinus - 11-19-2016, 04:07 PM
RE: Is the Wifi module working? - by pfeerick - 11-19-2016, 06:40 PM
RE: Is the Wifi module working? - by clawinus - 11-21-2016, 04:16 PM
RE: Is the Wifi module working? - by pfeerick - 11-21-2016, 07:06 PM
RE: Is the Wifi module working? - by clawinus - 11-23-2016, 10:09 AM
  USB adapter to eMMC module not recognized danril 0 1,385 11-25-2022, 04:16 AM
Last Post: danril
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,610 10-06-2022, 08:46 PM
Last Post: ihab
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,949 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Ctrl + Shift + Tab not working in Firefox Bolitoglossa 2 4,174 08-21-2020, 04:05 AM
Last Post: Bolitoglossa
  Cannot charge and NO Wifi? jiapei100 3 5,514 06-27-2020, 02:11 PM
Last Post: jiapei100
Bug WiFi enabled but refuses to connect cardboardmaster 6 7,917 06-02-2020, 11:56 PM
Last Post: pfeerick
  WiFi issues Pinebook Pro sunnystormy 6 9,156 05-28-2020, 05:44 PM
Last Post: Luke
  wifi issues george2524 9 10,991 06-13-2019, 04:25 PM
Last Post: evilbunny
  Input not working after a forced shutdown dic1911 1 3,517 12-24-2018, 07:45 PM
  Any success working with OpenCV on the PineA64? Tonny91 0 2,485 10-16-2018, 09:16 PM
Last Post: Tonny91
