Using Pine cluster for Docker Swarm
Some answers that I have come up with:
1) OS
Went with Ubuntu base instead, because there are docker packages specifically available for the ubuntu base and arm64 architecture.
2) Shared Storage
For now, just sticking with SD storage.
3) microSD storage per board
Went with 32GB to start
4) Accessing over the internet via SSH
noip is a breeze. I also have an ASUS RT-N56U router that i've got my two boards plugged into. I've set up the port forwarding on the router to route SSH to one of the boards, then I just ssh into the other boards via LAN IP.
The major gotcha is the arm architecture. There is limited support in Docker images for the arm64 architecture, but there is some. I figure I will need to rebuild the images for arm. Some great base images i've discovered:
- https://hub.docker.com/r/owlab/alpine-arm64/ Alpine image. Makes a great base for several official Docker images
- https://hub.docker.com/r/ericvh/arm64-ubuntu/
Using Pine cluster for Docker Swarm - by jpnh - 11-10-2016, 12:23 PM
RE: Using Pine cluster for Docker Swarm - by jpnh - 11-22-2016, 07:11 AM
  pine store paulhide 1 3,237 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 4,681 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 7,866 09-10-2019, 11:28 AM
Last Post: Pineapple
  PINE A64+ 4K Media Computer RWL 4 6,928 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 8,722 09-19-2018, 10:30 AM
Last Post: mjgoode
  sopine cluster board install Smurfbot 1 4,436 03-31-2018, 04:09 AM
Last Post: pfeerick
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 5,293 12-26-2017, 07:01 PM
  [PINE A64+ 2GB] Ubuntu - Losing Signal Arlanps 4 6,270 02-12-2017, 05:12 PM
Last Post: Arlanps
  Applying a fan for the Pine 64+? Maximum 5 9,588 01-20-2017, 03:34 PM
Last Post: Shad0wSt4R
  Pine 64 IR Receiver not working rajatgarg21 1 3,217 08-31-2016, 12:47 AM
Last Post: MarkHaysHarris777
