Using Pine cluster for Docker Swarm
I just received my first two Pine boards (2GB ram models). My dream is to network these together for use as a Docker Swarm cluster that would host various applications that I develop -- sort of a home-grown replacement for AWS or Docker Cloud. Although I am pretty familiar with Docker, I am rather new at devices like Pine boards. Would anyone be able to help me understand what I need to do to get a reasonably performant cluster that can scale as I purchase more Pine boards?
Here are some questions/thoughts I have:
1) OS
I was thinking Debian base here.
2) Shared Storage
I want shared storage to store docker volumes so that every board in the cluster can mount the volumes into containers.
My first thought was to buy a 1 or 2 TB external hard drive, but:
    a) How do i connect all the boards to the drive? Do I need to have the drive connected to one board and then share the mount over the network?
    b) What can I expect for IO latency? I want to be able to run postgres database containers against the volumes on the external drive. How will that perform?
3) microSD storage per board
This hits a limit on my docker knowledge -- i'm not sure if i need to have internal storage for all the images that I want my swarm to run, or whether the images can be stored on the shared storage from 1) and just loaded into memory when i instantiate containers. If the images must be kept on the microsd, I guess i would need 32 or 64 GB. But if the images can be kept on shared storage, then i imagine i would only need a microsd large enough for the OS and whatever disk space the docker daemon needs to do its job.
4) Accessing over the internet via SSH
I was thinking instead of buying a static IP, which would require business class from my cable company, to use a service like http://www.noip.com/. I want to be able to SSH into this cluster via the domain name, and of course be able to hit web applications over HTTP.
This is as far as I have gotten so far. I am sure there are gaps in my understanding above. Also please point out to me anything I am NOT thinking of that is crucial to my goal of a personal docker swarm cluster -- any help is appreciated!!!
Using Pine cluster for Docker Swarm - by jpnh - 11-10-2016, 12:23 PM
RE: Using Pine cluster for Docker Swarm - by jpnh - 11-22-2016, 07:11 AM
  pine store paulhide 1 3,218 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 4,655 03-18-2020, 08:41 AM
  Pine HDMI -> DVI monitor Pineapple 4 7,813 09-10-2019, 11:28 AM
Last Post: Pineapple
  PINE A64+ 4K Media Computer RWL 4 6,896 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 8,700 09-19-2018, 10:30 AM
Last Post: mjgoode
  sopine cluster board install Smurfbot 1 4,419 03-31-2018, 04:09 AM
Last Post: pfeerick
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 5,265 12-26-2017, 07:01 PM
  [PINE A64+ 2GB] Ubuntu - Losing Signal Arlanps 4 6,250 02-12-2017, 05:12 PM
Last Post: Arlanps
  Applying a fan for the Pine 64+? Maximum 5 9,570 01-20-2017, 03:34 PM
Last Post: Shad0wSt4R
  Pine 64 IR Receiver not working rajatgarg21 1 3,201 08-31-2016, 12:47 AM
Last Post: MarkHaysHarris777
