WiFi PineA64 Pineapple
I went through some of my crap and found this old linksys wrt54g router and the big external n-type connector antennas.
Running through some airodump tests I found the big antennas being compairable to my 11db rp-sma antennas I have. So now if I can't mount my wireless cards securly with rp-sma, I can always use the original connectors
Now to do the mounting.
I also have a 5000mah 3.7v battery floating around for power options
Edit: I thought it was 5000mah as it was in a 5000mah battery pack I got for playing ingress ages ago but when I pulled it apart the battery is only rated at 2500mah. Ill do some tests with the 2 wireless cards and see how long it will last.
Edit2: just tried the battery, it charges nicely but not enough power to run the wifi cards.
Edit3: man I'm a dill. Forgot about the battery jumper so the usb ports didn't have power. So I have tested packet injection on both cards at the same time running only from battery and it works.
WiFi PineA64 Pineapple - by Ghelorn - 09-19-2016, 07:48 AM
WiFi PineA64 Pineapple - by Ghelorn - 09-22-2016, 03:29 AM
RE: WiFi PineA64 Pineapple - by Ghelorn - 09-25-2016, 03:05 AM
  PineA64+: Audio in 5.0 Kernel puzzles 6 9,093 11-13-2019, 09:41 AM
Last Post: roel
  WiFi dongle MediaTek mt7601u Beta_Ravener 13 22,190 11-28-2017, 11:58 AM
Last Post: Aadhyatm
  Pre-Configure Wifi on Pine64 without Keyboard/mouse bortek 4 7,661 01-23-2017, 02:04 PM
Last Post: bortek
Question Driver usb wifi dongle 8192eu Pander 8 12,359 07-16-2016, 04:03 PM
Last Post: CaptainZalo
  third party wifi rahlquist 3 5,147 04-27-2016, 02:39 PM
Last Post: baryluk
  .NET on PineA64? BostonBay 1 3,194 02-11-2016, 06:17 PM
Last Post: taros
