LCD touch pad blank screen
(08-30-2016, 05:28 PM)Ghost Wrote:
(08-30-2016, 05:01 PM)tanarri Wrote:
(08-30-2016, 04:07 PM)Ghost Wrote:
(08-30-2016, 03:22 PM)tanarri Wrote:
(08-30-2016, 03:17 PM)Ghost Wrote: What power supply are you using? Have you had success using the HDMI image and connecting to a TV screen or monitor? Just trying to whittle down the possibilities.
It's the power supply that came with my kickstarter. I have been able to use the HDMI without problems with my original OS/memory card. I suppose it could be a problem with the SD card but the screen didn't light up with the hdmi image.
It could be an image burning issue, have you tried to burn a DD image using one of the available methods, instead of a PhoenixCard image?
I have not. I am not 100% sure what the best method is for burning a non phoenix card image is.
There is no best method, though Win32DiskImager might be easiest. Download that here:
https://sourceforge.net/projects/win32di...e/download
Then try the 8GB image, just to see if it works:
http://files.pine64.org/os/android/andro...64-8GB.zip
I just want to make sure I did this right since the results are worse. With windiskimager select the device select the image and just click write?
LCD touch pad blank screen - by tanarri - 08-30-2016, 09:16 AM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 02:36 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 02:54 PM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 03:17 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 03:22 PM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 04:07 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 05:01 PM
RE: LCD touch pad blank screen - by Ghost - 08-30-2016, 05:28 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 07:38 PM
RE: LCD touch pad blank screen - by Terra854 - 08-30-2016, 08:40 PM
RE: LCD touch pad blank screen - by tanarri - 08-30-2016, 10:50 PM
RE: LCD touch pad blank screen - by JMBRauch - 09-14-2016, 03:32 PM
RE: LCD touch pad blank screen - by tanarri - 09-14-2016, 08:22 PM
RE: LCD touch pad blank screen - by Ghost - 09-14-2016, 09:41 PM
RE: LCD touch pad blank screen - by Arvin - 09-19-2016, 05:07 PM
RE: LCD touch pad blank screen - by Ghost - 09-21-2016, 01:25 AM
RE: LCD touch pad blank screen - by tkaiser - 09-21-2016, 01:35 AM
RE: LCD touch pad blank screen - by Ddorrer - 09-22-2016, 06:16 AM
RE: LCD touch pad blank screen - by Ghost - 09-22-2016, 06:34 AM
RE: LCD touch pad blank screen - by Ddorrer - 09-22-2016, 12:53 PM
RE: LCD touch pad blank screen - by Ghost - 09-22-2016, 01:20 PM
  Reformatting postmarket os with ubuntu touch mackdaddy67 6 8,526 09-11-2020, 12:41 AM
Last Post: SwordfishII
  7" LCD Touch Screen Panel IanJames 0 2,089 04-01-2020, 04:40 PM
Last Post: IanJames
  User Screen Black After Changing Power Settings 0b51Gekko 2 4,801 07-03-2019, 07:53 AM
Last Post: 0b51Gekko
  Rock64 + 7" touch screen naviathan 2 5,078 09-28-2017, 09:01 AM
Last Post: naviathan
  7" Screen - Does it work with Debian abasel 1 3,945 07-26-2017, 05:44 AM
Last Post: pfeerick
  RESOLVED - LCD screen not working, HDMI does asuras 10 16,126 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI-VGA adapter. Blank screen. trumad 10 18,068 03-05-2017, 03:17 AM
Last Post: pfeerick
  Does ubuntu img support the touch screen kingsing2 4 7,542 01-29-2017, 02:41 PM
Last Post: greglarious
  Can't get past boot screen... (RESOLVED) codetheweb 13 23,900 01-19-2017, 08:43 AM
Last Post: Michaelrowe01
  How to open Playbox with screen installed? LAPine 3 5,115 12-03-2016, 05:17 PM
Last Post: LAPine
