Cross-wired Uart Ports between two Pine Boards via Cat5 Cable
The best way to use connectors ( for this use case , cross-wiring between two pines ) is to use good 'ol regular RJ45 connectors.
Make the cat5 cable youself and do the cross-over in the cable; male RJ45 standard plugs.
On the female RJ45 jacks mounted in the ABS boxes ( or where ever ) run the wiring from the RJ45 to female connectors for plug-in to the uart(s) on the respective pine boards.
Note:   I have done this on my cross-over and it worked very nicely. I tagged my cat5 cross-over cable at each end so that its obvious to me that its NOT an ethernet cable !  I also tagged the RJ45 female jacks on the ABS boxes to denote the jack as serial console cross-over port vs  ethernet port.
RE: Cross-wired Uart Ports between two Pine Boards via Cat5 Cable - by MarkHaysHarris777 - 11-19-2016, 06:42 PM
  RPi.GPIO python module for Pine A64/A64+ aquilegia 98 132,644 12-15-2022, 08:40 PM
Last Post: Fadazo
  Exp Header UART for TTL is True Serial Console (very nice) MarkHaysHarris777 12 17,043 08-01-2016, 10:37 AM
Last Post: MarkHaysHarris777
