Which of the following best describes your ethernet situation on the PineA64? (read first post, post your answers after the poll)
GbE ethernet has always worked on my PineA64 (regardless of OS choice)
5.88%
3
GbE ethernet has never worked on my PineA64 (regardless of OS choice)
76.47%
39
GbE ethernet NOW works on my PineA64 by changing the environment or configuration
9.80%
5
I'm not interested in GbE ethernet
0%
0
I don't use ethernet 10/100/1000 primarily
0%
0
My machines are primarily connected via wifi
1.96%
1
other
5.88%
3
51 vote(s)
GbE Ethernet Port Issue Data Gathering Statistics Intel
1) Pine64+ 2GB - Serial 410640173729 - Board 201-A64DB110-02 A64-DB-V1.1 2G C160680 07.02
2) RTL chip numbers: RTL8211E G3F73H1 GG12B
3) Router/Modem: ZyXEL NBG6716
4) if you modded your board and made it work, how? N/A
5) if you swapped out your switch or router and made it work, what or which? N/A - have tried three different switches and different cables
6) if GbE is critical to your operation, please tell us how so? GbE is critical. Throughput is critical to meet business need
7) provide any other additional 'data only' that might be helpful.No data only info available
RE: GbE Ethernet Port Issue Data Gathering Statistics Intel - by mark0710@ - 09-01-2016, 02:17 AM
  Ethernet port down afert 1 day jeda 0 671 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 5,388 05-16-2017, 03:41 AM
Last Post: m17
  What will it take to get the Ethernet port working? clarkss12 10 16,720 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 115,511 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 16,000 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,415 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 6,215 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
