USB Capture Card??
(08-01-2016, 11:05 PM)AUDIOTEK Wrote: Would this USB video capture card work with Android 5.1 plus touchscreen I have installed
It's a AV.Io Capture card.
https://www.epiphan.com/products/avio-sdi/
Here's the minimum requirements
Video capture workstation operating system Windows 7, Windows 8.1, Windows 10 Mac OS X 10.10 and up Linux distribution with kernel 3.5.0 or higher
On the download page it says Ubuntu 14.04 LTS 64-bit and similar
https://www.epiphan.com/products/avio-sd...downloads/
Hmm, my guess is no since Android isn't one of the listed supported operating systems.
There may be ways to get it to work, but it definitely wouldn't be a plug and play experience, I wouldn't have thought. It depends if Android is similar enough to Ubuntu, which I don't think it is (despite both being Linux-based).
USB Capture Card?? - by AUDIOTEK - 08-01-2016, 11:05 PM
RE: USB Capture Card?? - by Ghost - 08-02-2016, 06:37 AM
RE: USB Capture Card?? - by AUDIOTEK - 08-02-2016, 08:45 AM
RE: USB Capture Card?? - by MarkHaysHarris777 - 08-02-2016, 09:27 AM
  PoE Daughter card Option? bigmacattack 3 6,704 02-10-2016, 07:10 PM
Lightbulb Server Oriented Card JigenEagle 9 12,907 01-20-2016, 07:00 AM
Last Post: hazerty
