uboot wont boot to SD card after upgrade
The boot rom search order is fixed (spi, emmc, sd), if you have a serial terminal
you can alter uboot priority .... setenv boot_targets mmc1 ; boot
some uboots will look to sd (mmc1) first, check with.... strings u-boot.itb|grep _targets
OR install tow-boot
OR save emmc 1st 16M, save emmc mbr, blank emmc 1st 16M, restore emmc mbr, make a small sd boot card for emmc boot
Since the only uboot is on sd, that is what will boot, if the sd has no boot cfg files will then look to emmc
boot cfg files = boot.scr (or boot/boot.scr), extlinux.conf (in appropriate 2 paths), aarch64.efi
RE: uboot wont boot to SD card after upgrade - by wdt - 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 317 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,346 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 743 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 630 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,256 09-19-2023, 08:48 AM
Last Post: dachalife
  Will it be possible to upgrade the Pinebook Pro if/when a newer model is released? Rat24 4 1,497 09-15-2023, 03:00 PM
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,969 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 820 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 2,002 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,496 05-20-2023, 01:02 AM
Last Post: jackwilson
