bookworm vs trixie discussion for mobian in pinephone regular.
#24
(04-28-2024, 09:27 AM)anonymous Wrote:
(04-28-2024, 08:54 AM)zetabeta Wrote:
(04-28-2024, 07:10 AM)anonymous Wrote: I have just done a full upgrade and I can no longer boot Sad Please help me.
if you would be locally (physically) nearby, let's look at it. knowing what is ahead, i think best course of action is to reinstall, and temporarily i suggest other than mobian.
however:
does it boot somewhere? so you can get virtual console, i.e. ctrl-alt-f3. (usb dongle and keyboaard is required)
does it get a internet through wifi? internet is not dependent on gui.
you probably do not have sshd installed, which can be used for remote management.
software "aptitude" helps, but you still need to know some thing about packages and their dependencies.
I'm trying to reinstall Mobian from the installer released at March 3rd 2024 but I get an error message "Is host ready?" when I boot Sad
P.S: I'm trying to use the more recent image suggested by Walter...
P.S: The image suggested by Walter works but I need a working installer as I use full disk encryption, I want to install the system on the EMMC, Tow-Boot is already installed.
P.S: The installer works now.
P.S: I've succeeded in reinstalling everything but I'll wait some days before updating and upgrading.
i installed version "da4f550c910aa4fa8d8922cfa9676f00a30c49d0dda1f2cb0febaae95971876b  mobian-installer-sunxi-phosh-20240303.img.xz" on a pinephone regular, and using full disk encryption into emmc storage. it went fine. installation of tow-boot may be required afterwards depending on a case.
i try to give instructions how to proceed afterwards. at least disable automatic updates in software "software".
RE: bookworm vs trixie discussion for mobian in pinephone regular. - by zetabeta - 05-03-2024, 04:17 AM
  atinout binaries for mobian/debian? NeutralGrey 2 151 05-13-2024, 02:42 PM
Last Post: Gumur
  Mobian repository status henrythemouse 16 9,215 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 189 03-18-2024, 08:54 PM
Last Post: penguins_rule
  Phoch Trixie weekly install seems nice reTestability 0 247 03-10-2024, 08:47 AM
Last Post: reTestability
  unofficial kali linux for pinephone help needed pinesmell 5 3,799 01-08-2024, 02:50 PM
Last Post: ERPlegend
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,190 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,915 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 673 09-01-2023, 11:29 AM
Last Post: Mahgue
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,838 08-31-2023, 12:38 PM
Last Post: vusra
  how to update mobian over tor vusra 13 7,237 07-09-2023, 08:57 PM
Last Post: vusra
