Wifi module able to share ethernet connection? Connection is unstable!
I noticed that when pine64 and the client device are too close (couple of feet) connectivity may not work at all, it is more stable if
1. there's at least 6+ feet between them
2. no major metal obstacles on the way (like in my case there were garage gate made of sheet metal) that was blocking connectivity.
I also tried external antenna for Pine64 wifi (5Dbi RP-SMA Antennas), which did not help much. WiFi works okay in the room
if pine is plugged in in one corner of the room and i connect to it from another corner.
ps. Interestingly enough, same garage gate is not an obstacle for RaspberryPI 3 wifi AP.
pps.I would look into syslog on pine64 to see if you can find some clues why connectivity is not established ...
RE: Wifi module able to share ethernet connection? Connection is unstable! - by vigor - 10-10-2016, 10:12 AM
  [split] Better WiFi/BT module? moriel5 3 5,052 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 4,753 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 25,010 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 4,166 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 27,103 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 9,739 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 2,032 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 3,574 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 15,902 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 6,064 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
