What will it take to get the Ethernet port working?
(07-25-2016, 02:29 PM)xalius Wrote: Are all the boards reported with GbE issues 2GB variants? If so, are there differences in the GbE implementation regarding to the layout?
As our understanding, this issue seems happen on both 1GB and 2GB boards. Due to there are more 2GB boards in the field, it may appear that that related to 2GB board. The GbE PCB routing circuit between 1GB and 2GB board should be identical. There is one theory whether is related to different batch of Realtek RTL8211 Phy chip, this chip was in short supply due to Taiwan earthquake and our manufacturer need to purchase at open market (at higher price) to fulfill the KS delivery. I have go thru this checking with one backer and he has 3 2GB boards able to connect to GbE successfully but one 2GB board cannot, and discovered the all 4 boards Realtek RTL8211 comes from same batch thru inspecting the chip marking.
RE: What will it take to get the Ethernet port working? - by tllim - 07-25-2016, 02:47 PM
  Ethernet port down afert 1 day jeda 0 647 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 5,333 05-16-2017, 03:41 AM
Last Post: m17
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 24,664 01-17-2017, 01:17 AM
Last Post: DrunkTank
  Ethernet Slow Download Ascotg 89 114,050 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 15,787 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 2,390 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 6,145 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
