Sound : notifications
(06-06-2023, 06:58 AM)alaraajavamma Wrote:
(06-06-2023, 06:34 AM)freelectro Wrote: Hi all,
To keep 4G active to receive notification from nheko and dino software, i use the following script.
https://gitea.privatedns.org/Xavi92/pinephone-scripts
Now, i receive notifications but i have no sound when receive.
I don't think it's due too this script.
How can i resolved this sound problem ?
Thanks a lot
When you are on lock screen notifications arrive as missed.
How notification are handled is configured here:
/usr/local/share/feedbackd/themes/
There are several config files and maybe you find correct one inside pine64,pinephone.json or default.json
Somewhere inside those files are examples for notifications who does make a sound - like message-new-sms
For example you can replace config of "message-new-sms" to "message-missed-instant" or "message-missed-email" and then you will get notification sound.
These two are the ones you want to find
And they are most likely under "silent" or "quiet" profile.
Thank you, and fore other software (nheko and dino software), how it's possible to get this properties ?
When you said : "When you are on lock screen notifications arrive as missed. "
When the screen is off, what is the current state ?
I have done this and it have disable vibration of virtual keyboard.
gsettings set org.sigxcpu.feedbackd.application:/org/sigxcpu/feedbackd/application/sm-puri-squeekboard/ profile silent
But what can be the name of nheko and dino ? And what signals are available to manage ?
Sound : notifications - by freelectro - 06-06-2023, 06:34 AM
RE: Sound : notifications - by alaraajavamma - 06-06-2023, 06:58 AM
RE: Sound : notifications - by freelectro - 06-06-2023, 07:33 AM
RE: Sound : notifications - by alaraajavamma - 06-06-2023, 11:17 AM
RE: Sound : notifications - by freelectro - 06-06-2023, 02:05 PM
RE: Sound : notifications - by alaraajavamma - 06-06-2023, 02:18 PM
RE: Sound : notifications - by freelectro - 06-07-2023, 01:03 AM
  Does tow-boot allow periodic wake from suspension to check for notifications? DrPlamsa 4 2,808 12-31-2022, 10:56 AM
Last Post: DrPlamsa
Exclamation No sound anonymous 22 9,643 11-08-2022, 09:07 AM
Last Post: dante404
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 2,853 02-18-2022, 08:54 AM
Last Post: battlegarden
  Lost all sound Dinosaur1946 0 1,116 01-27-2022, 07:34 PM
Last Post: Dinosaur1946
  Sound design for Mobian S.E.B 4 3,454 12-27-2021, 05:40 AM
Last Post: Anna
  Customized Notifications - Non-native Apps arno_nuehm 2 2,362 10-05-2021, 09:42 AM
Last Post: kqlnut
  No notifications on lock screen DrPlamsa 16 8,716 08-21-2021, 05:35 AM
Last Post: bcnaz
  A clear all button for notifications is coming! ragreenburg 0 1,354 08-13-2021, 09:09 AM
Last Post: ragreenburg
  Software/Notifications battlegarden 4 4,239 05-01-2021, 03:22 PM
Last Post: MtnSk8
  Phone Shell and Dismissing Notifications on Mobian publiclewdness 0 1,455 04-10-2021, 01:41 PM
Last Post: publiclewdness
