Lost all sound
Hi All
Just when I got everything installed and working the way I wanted (including waydroid) , I discovered that I have lost all sounds.
I get no sound on testing the Left/Right speaker test. All settings appear enabled.
Phone ring and speaker both silent.
However I did get rid of a lot of apps in waydroid.
So I uninstalled waydroid and purged everything to do with it. Still no sound.
I have backup .img files, and concluded that waydroid or removing apps was to blame.
I did read somewhere that it takes over the sound control.
Does anyone have any experience or knows how to re-assign the sound back to Mobian.
Regards
EDIT:
Noted that the following services are masked.
alsa-utils.service , it also has no content.
pulseaudio-enable-autospawn.service, it also has no content.
alsa-state.service is static but has content
alsa.restore.service is static but has content.
Now just to figure out which service should be started and running.
Tried removing and re-installing alsa-utils
  Sound : notifications freelectro 6 1,952 06-07-2023, 01:03 AM
Last Post: freelectro
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,207 03-01-2023, 04:45 PM
Last Post: anonymous
Exclamation No sound anonymous 22 9,053 11-08-2022, 09:07 AM
Last Post: dante404
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,867 09-11-2022, 09:24 PM
Last Post: Katsujinken
  SMS quit - "Lost dbus connection" 98cwitr 0 724 06-09-2022, 06:42 AM
Last Post: 98cwitr
  My sound went away with calls... Not sure what happened. How can i fix it? usourypg3i 4 2,743 02-18-2022, 08:54 AM
Last Post: battlegarden
  lost settings icon from screen kubussz 3 2,529 02-17-2022, 09:26 AM
Last Post: beretta
  Sound design for Mobian S.E.B 4 3,348 12-27-2021, 05:40 AM
Last Post: Anna
  lost settings icon from screen bobblestiltskin 2 3,195 11-19-2020, 01:07 PM
Last Post: bobblestiltskin
Bug Sound defaults to Headset User 18618 10 8,934 10-21-2020, 06:06 PM
Last Post: ThrillGates
