SD Card has wrong capacity
Are you sure it's actually 16GB capacity? There are a lot of phony flash drives and SD cards around, though usually higher reported capacities. (You buy a "64GB" card and find out it will only hold 4GB, etc.)
There is testing software out there to check actual physical capacity, such as this:
https://www.youtube.com/watch?v=2UihP7jqB7U
SD Card has wrong capacity - by AndyM - 06-04-2023, 07:27 AM
RE: SD Card has wrong capacity - by Zebulon Walton - 06-05-2023, 06:42 AM
RE: SD Card has wrong capacity - by Kevin Kofler - 06-06-2023, 01:04 AM
RE: SD Card has wrong capacity - by AndyM - 06-05-2023, 07:02 AM
RE: SD Card has wrong capacity - by zetabeta - 06-05-2023, 09:17 AM
RE: SD Card has wrong capacity - by AndyM - 06-07-2023, 01:52 AM
RE: SD Card has wrong capacity - by zetabeta - 06-07-2023, 03:42 AM
RE: SD Card has wrong capacity - by AndyM - 06-07-2023, 04:05 AM
RE: SD Card has wrong capacity - by KNERD - 06-10-2023, 05:15 PM
RE: SD Card has wrong capacity - by Kevin Kofler - 06-10-2023, 08:05 PM
RE: SD Card has wrong capacity - by AndyM - 06-11-2023, 12:30 AM
  install iso from sd card to emmc aular 2 468 03-11-2024, 10:24 PM
  How To Access the Pine Phone Auxillary microSD Without Removing Card pinephoneuser22 2 1,072 01-09-2024, 07:02 PM
Last Post: britelite
  Device Unable To Read MicroSD Card _radv_ 19 6,610 02-18-2023, 02:01 PM
Last Post: _radv_
  SIM Card Slot Terror thismarty 4 1,570 12-21-2022, 05:37 PM
Last Post: thismarty
  MicroSD Card Reuse _radv_ 5 2,172 12-12-2022, 12:26 PM
Last Post: chainingsolid
  Pine Phone Doesn't Recognize New MicroSD Card _radv_ 3 1,518 11-23-2022, 05:19 AM
Last Post: _radv_
  Boot problem: wrong screen orientation Jetpac 6 3,904 07-18-2022, 12:47 PM
Last Post: fravoi
  SIM Card Install pineme 4 5,250 06-10-2022, 03:15 AM
Last Post: rocket2nfinity
  Flashing gone wrong erg 9 4,586 05-28-2022, 10:52 AM
Last Post: fxc
  SIM card slot not working dekrets 2 2,268 02-12-2022, 11:09 AM
Last Post: dekrets
