Star64: Armbian Installation
Information
There are quite a few possible variants of the installation process. Below instructions do not require a serial console. All steps are performed on a linux pc and not on the star64.
schaecsn@pc:~ mkdir riscv && cd riscv
Download armbian from the bottom of this page https://www.armbian.com/star64/, e.g. Armbian Sid CLI or Armbian Sid XFCE desktop.
dd armbian onto a micro sd card. For me, a micro sd card is /dev/sdb. YMMV:
schaecsn@pc:~/riscv$ xzcat Armbian_23.5.0-trunk.231_Star64_sid_edge_5.15.0.img.xz | sudo dd of=/dev/sdb status=progress
Above image does not boot from the micro sd card - it misses a device tree for the star64.
Even with a device tree, armbian's kernel shuts down all usb ports, e.g. keyboard and mouse. For all this to work, use Fishwaldo's kernel. It can be compiled on a Linux PC.
Install a cross-compiler. That is distribution dependent. On Debian, that would be
schaecsn@pc:~/riscv$ sudo apt-get install libncurses-dev libssl-dev bc flex bison make gcc gcc-riscv64-linux-gnu
Download Fishwaldo's kernel
schaecsn@pc:~/riscv$ git clone https://github.com/Fishwaldo/Star64_linux linux
schaecsn@pc:~/riscv$ cd linux
Configure this kernel (CONFIG_SECCOMP is needed by armbian's default systemd service chrony)
schaecsn@pc:~/riscv/linux$ make ARCH=riscv CROSS_COMPILE=riscv64-linux-gnu- pine64_star64_defconfig
schaecsn@pc:~/riscv/linux$ scripts/config -e CONFIG_SECCOMP
schaecsn@pc:~/riscv/linux$ scripts/config -d CONFIG_SECCOMP_CACHE_DEBUG
Apply possible patches:
Crosscompile the kernel
schaecsn@pc:~/riscv/linux$ make -j4 ARCH=riscv CROSS_COMPILE=riscv64-linux-gnu-  bindeb-pkg
Above step creates these files and directories
schaecsn@pc:~/riscv/linux$ ls -lad ../linux-image-5.15.107-15659-g7943fd6427b0-dirty_5.15.107-15659-g7943fd6427b0-dirty-1_riscv64.deb arch/riscv/boot/Image  debian/linux-image/lib/modules/5.15.107-15659-g7943fd6427b0-dirty/ debian/linux-image/usr/lib/linux-image-5.15.107-15659-g7943fd6427b0-dirty
-rw-r--r-- 1 schaecsn staff 19734212 May 28 22:47 ../linux-image-5.15.107-15659-g7943fd6427b0-dirty_5.15.107-15659-g7943fd6427b0-dirty-1_riscv64.deb
-rwxr-xr-x 1 schaecsn staff 26410944 May 28 22:45 arch/riscv/boot/Image
drwxr-xr-x 3 schaecsn staff    4096 May 28 22:46 debian/linux-image/lib/modules/5.15.107-15659-g7943fd6427b0-dirty/
drwxr-xr-x 4 schaecsn staff    4096 May 28 22:46 debian/linux-image/usr/lib/linux-image-5.15.107-15659-g7943fd6427b0-dirty
The correct way to install Fishwaldo's kernel / modules / device tree would be to run this command on a booted star64 system
sudo dpkg -i linux-image-5.15.107-15659-g7943fd6427b0-dirty_5.15.107-15659-g7943fd6427b0-dirty-1_riscv64.deb
I'm not awfully familiar with armbian. For some reason, the generated deb does not correctly install itself into the /boot directory. On top of this, we can't boot the current armbian installation as it misses a device tree, anyway.
A workaround is a manual installation of the kernel / modules / device tree.
Find an empty directory, say /mnt/tmp and mount the micro sd card on it:
schaecsn@pc:~/riscv/linux$ sudo mount /dev/sdb1 /mnt/tmp
Remove symbolic links of the kernel and device tree directory on the micro sd card (there is no need to make changes to the module directory as the old and new module directory names differ)
schaecsn@pc:~/riscv/linux$ sudo rm /mnt/tmp/boot/Image /mnt/tmp/boot/dtb
Copy over our kernel / modules / device tree on the micro sd card
schaecsn@pc:~/riscv/linux$ sudo rsync -avzH debian/linux-image/usr/lib/linux-image-5.15.107-15659-g7943fd6427b0-dirty /mnt/tmp/boot/dtb
schaecsn@pc:~/riscv/linux$ sudo rsync -avzH arch/riscv/boot/Image /mnt/tmp/boot/
schaecsn@pc:~/riscv/linux$ sudo rsync -avzH debian/linux-image/lib/modules/5.15.107-15659-g7943fd6427b0-dirty /mnt/tmp/lib/modules
Fix a typo of the device tree name in extlinux
schaecsn@pc:~/riscv/linux$ sudo sed -i s/jh7110-star64-pine64.dtb/jh7110-pine64-star64.dtb/ /mnt/tmp/boot/extlinux/extlinux.conf
Done
schaecsn@pc:~/riscv/linux$ sudo umount /dev/sdb1
Next boot the micro sd card on the star64.
schaecsn@192.168.0.216's password:
____  _              __  _  _
/ ___|| |_ __ _ _ __ / /_ | || |
\___ \| __/ _` | '__| '_ \| || |_
___) | || (_| | |  | (_) |__  _|
|____/ \__\__,_|_|  \___/  |_|
Welcome to Armbian 23.05.0-trunk Bookworm with bleeding edge Linux 5.15.107-15659-g7943fd6427b0-dirty
No end-user support: built from trunk
System load:  54%              Up time:      0 min
Memory usage:  1% of 7.73G      IP:            192.168.0.216
CPU temp:      50°C            Usage of /:    23% of 7.2G
RX today:      44.0 MiB
[ 0 security updates available, 12 updates total: apt upgrade ]
Last check: 2023-05-21 15:22
Last login: Sun May 21 15:23:30 2023 from 192.168.1.231
schaecsn@star64:~$
Tuning after a first boot:
[   21.771962] Bluetooth: hci0: RTL: firmware file rtl_bt/rtl8852bu_fw.bin not found
This firmware blob for bluetooth comes from  armbian-firmware-full. Install it
schaecsn@star64:~$ sudo apt-get remove armbian-firmware
schaecsn@star64:~$ sudo apt-get install armbian-firmware-full
Possibly install GPU firmware as described in https://forum.pine64.org/showthread.php?tid=18301
Our integration of the kernel / module / device tree shortcuts the package management and armbian kernel / modules / device tree updates may overwrite our own versions.
My first try was deinstalling armbian's kernel / modules / device tree package. That turned out to have disadvantages. Packages that modify initrd trigger commands which come with the kernel package and fail updating the initrd.
For now, I can only suggest to manually copy over our kernel / modules / device tree whenever armbian overwrites them with its own versions.
On the long, armbian should better support the star64 and custom kernel / modules /device trees should not be necessary, anymore.
I was also playing around with ubuntu's riscv port. There, custom kernels can be installed with dpkg -i linux-image*.deb. They hook themselves up to grub and peacefully co-exist with the vanilla kernel.
Please post corrections and possible improvements (in particular on how to better make our own kernel co-exist with the package management).
Star64: Armbian Installation - by Der Geist der Maschine - 05-29-2023, 01:07 AM
RE: Star64: Armbian Installation - by tantamount - 05-30-2023, 02:41 PM
RE: Star64: Armbian Installation - by tantamount - 05-31-2023, 02:23 PM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 184 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Star64 JH7110 (slarm64, riscv64) mara 2 1,190 10-09-2023, 03:43 AM
  Star64: GPU firmware loading on Armbian Der Geist der Maschine 13 4,760 09-29-2023, 05:46 PM
  Star64: jtag debugging? bluepill 1 1,043 09-20-2023, 08:26 AM
Last Post: bwooster0
  Star64: 4GB on 8GB boards Der Geist der Maschine 4 2,131 07-27-2023, 12:32 AM
Last Post: balbes150
  Star64: SATA Der Geist der Maschine 1 1,100 07-26-2023, 12:35 PM
Last Post: Gladox114
  Star64: a first benchmark Der Geist der Maschine 0 1,089 05-29-2023, 01:00 PM
  Star64 first boot (and success) bortzmeyer 1 1,690 05-24-2023, 02:45 AM
Last Post: draintroup
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,949 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Probably stupid question from me re: installation RAK64pine 7 9,204 05-23-2016, 07:50 AM
Last Post: RAK64pine
