Star64: 4GB on 8GB boards
I have 8 GB of physical memory and I get that on Fishwaldo's image.
When using his kernel, modules and device tree from https://github.com/Fishwaldo/Star64_linux on Armbian https://www.armbian.com/star64/, I get only 4 GB of physical memory.
root@star64:/usr/src/linux# dmesg | grep Memory
[    0.000000] Memory: 2970040K/4192256K available (10967K kernel code, 7217K rwdata, 4096K rodata, 2189K init, 405K bss, 435784K reserved, 786432K cma-reserved)
Note, in these early days, Fishwaldo's kernel is a must-have way superior over other kernels.
I have not familiarized myself with the ins and outs of the boot process and don't understand where it fails on Armbian and perhaps other distributions.
The easiest workaround is setting the memory requirements to 8GB in the device tree
root@star64:/usr/src/linux# git diff
diff --git a/arch/riscv/boot/dts/starfive/jh7110-pine64-star64.dtsi b/arch/riscv/boot/dts/starfive/jh7110-pine64-star64.dtsi
index a6517cb4178a..d39e1377db73 100755
--- a/arch/riscv/boot/dts/starfive/jh7110-pine64-star64.dtsi
+++ b/arch/riscv/boot/dts/starfive/jh7110-pine64-star64.dtsi
@@ -47,7 +47,7 @@ cpus {
        memory@40000000 {
                device_type = "memory";
-              reg = <0x0 0x40000000 0x1 0x0>;
+              reg = <0x0 0x40000000 0x2 0x0>;
        reserved-memory {
After applying above patch, rebuild the device tree as usual:
root@star64:/usr/src/linux# make starfive/jh7110-pine64-star64.dtb
root@star64:/usr/src/linux# cp arch/riscv/boot/dts/starfive/jh7110-pine64-star64.dtb /boot/dtb/starfive/jh7110-star64-pine64.dtb
root@star64:/usr/src/linux# reboot
This patch against Fishwaldo's kernel gives me 8 GB of memory on Armbian:
[    0.000000] Memory: 7100836K/8386560K available (10967K kernel code, 7217K rwdata, 4096K rodata, 2189K init, 405K bss, 499292K reserved, 786432K cma-reserved)
Star64: 4GB on 8GB boards - by Der Geist der Maschine - 05-25-2023, 10:40 PM
RE: Star64: 4GB on 8GB boards - by Fishwaldo - 06-06-2023, 12:19 AM
RE: Star64: 4GB on 8GB boards - by balbes150 - 07-12-2023, 11:57 PM
RE: Star64: 4GB on 8GB boards - by Gladox114 - 07-26-2023, 12:33 PM
RE: Star64: 4GB on 8GB boards - by balbes150 - 07-27-2023, 12:32 AM
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 172 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  Star64 JH7110 (slarm64, riscv64) mara 2 1,177 10-09-2023, 03:43 AM
  Star64: GPU firmware loading on Armbian Der Geist der Maschine 13 4,707 09-29-2023, 05:46 PM
  Star64: jtag debugging? bluepill 1 1,032 09-20-2023, 08:26 AM
Last Post: bwooster0
  Star64: SATA Der Geist der Maschine 1 1,086 07-26-2023, 12:35 PM
Last Post: Gladox114
Information Star64: Armbian Installation Der Geist der Maschine 5 4,570 06-03-2023, 01:26 PM
  Star64: a first benchmark Der Geist der Maschine 0 1,076 05-29-2023, 01:00 PM
  Star64 first boot (and success) bortzmeyer 1 1,676 05-24-2023, 02:45 AM
Last Post: draintroup
  Need help in selecting boards ripcord 1 3,419 03-06-2019, 01:37 PM
  Linking the boards to make a server? Ramlatus 3 6,894 01-27-2018, 01:02 PM
Last Post: 11b2p508
